Need help ASAP
Old 05-25-2015, 08:34 AM
zackjk's Avatar
Default Need help ASAP
Last night I went the weather called for a 0% chance of rain all night. I left my 07 Wrangler out all night without the top in doors. I went out the next morning and everything is soaked. I assumed everything is okay, since I have seen tons of people do this before, and after all it's a Jeep. A couple hours later my horn randomly starts beeping out of no where and there was no way to stop it. It started beeping in random outbreaks about every two minutes. I'm worried something is messed up with the electrical. Anyone had something like this happen to them before? Or have any advice. Thanks
Old 05-25-2015, 09:17 AM
Ryan0260's Avatar
It should dry out. I would disconnect the horn for now and give it some time to dry.
Old 05-25-2015, 09:27 AM
14Sport's Avatar
Hopefully it's not the clockspring.
Old 05-25-2015, 09:34 AM
zackjk's Avatar
Yep I have read about the clock spring. Looks expensive. Hoping it will dry out
Old 05-25-2015, 09:37 AM
zackjk's Avatar
Thanks by the way. Praying for your wife.
Old 05-25-2015, 10:23 AM
RubiKing's Avatar
I replaced my clockspring myself for the price of the part. It was under 200 if I remember correctly. The hardest part is getting the horn off. I got a flat head screwdriver and bent the tip at a 90 degree angle and used that to undo the clips that hold the horn on. That's the only hard part of that install. Don't forget to disconnect the battery before you take the airbag off. All in all its not the end of the world if you have to replace the clockspring.
In fact I think the 2007 clocksprings are covered under factory warranty.
Old 05-25-2015, 10:32 AM
Mark Doiron's Avatar
True for select manufacturing dates. Up to 150K miles. Had mine replaced at 147K miles on Chrysler's nickel (horn inop). As stated, give a chance to dry out and it will probably be okay.
Old 05-25-2015, 10:38 AM
14Sport's Avatar
Yeah it's a $200 part and an hour or so to install it from what I've seen. The dealer would be a lot higher with labor of course. I believe the warranty was extended to 10 years or 150K miles for the 07 on the CS. Not sure if that includes a warranty on one that has already been replaced though, which may or may not be the case here.
Old 05-25-2015, 11:33 AM
augichef's Avatar
Just changed my clock spring out last week.. $165 on Amazon from a jeep dealer.. Installed in 30mins, give or take 10min..
Good luck
Augi
Old 05-25-2015, 02:18 PM
zackjk's Avatar
Thanks for the replies everyone. Just connected the battery and so far so good!
Quick Reply: Need help ASAP
