New JK Owner, Cruise Control won't work...
Old Oct 24, 2017 | 11:22 AM
PYCool's Avatar
Default New JK Owner, Cruise Control won't work...
Greetings...
I am new to the forum. I just purchased a 2012 JK. On my way home from dealer, I discovered the cruise control would not turn on or function. I also noticed that the trip odometer, mileage tracker function only worked intermittently. I could get it to work a bit if I turned off the dashboard lights, but, then it quit again.
My dealer said they would fix any problems, but, I am trying to do some troubleshooting in advance in case they are not familiar with Jeeps. I have read some things about TPIM failures or perhaps simply the steering wheel modules are the problem.
Has anyone had a similar experience and what was the fix?
Thanks.
Old Oct 24, 2017 | 11:29 AM
Arson's Avatar
Might be the clockspring???? There are recalls for it from the factory.
Old Oct 24, 2017 | 11:34 AM
PYCool's Avatar
Default Thanks Arson!
Can you tell me what this "clockspring" does? Does it handle multiple electrical components?
Old Oct 24, 2017 | 11:39 AM
Arson's Avatar
It's in the steering wheel it can cause weird things, horn not to work, cruise control not to work,, funny lights blinking on the dash. Not sure what all it does, but there are lot's out there that have had it replaced.
Old Oct 24, 2017 | 11:48 AM
PYCool's Avatar
Default Good Info..
Sounds promising. This could very well be the problem, especially when you say it is a common issue. I will check with local Jeep dealer about the recall. Thanks again.
Old Oct 24, 2017 | 02:36 PM
rob_engineer's Avatar
I think recall is the wrong word. More like extending the warranty on the clockspring. A recall would mean that they should replace it even if there are no symptoms.
Old Oct 27, 2017 | 10:51 AM
jedg's Avatar
Vet Army
Rob is correct. The recall applies to 2007-2010 jeeps. There is an extended warranty on the 2011+ jeeps. I had the clock spring replaced on my 2011 using that warranty. The difference between the recall and warranty is this.
Recall - dealership will replace it regardless of the condition of the clock spring (failing or operating correctly)
Warranty - dealership will only replace it if the clock spring has actually failed.
Old Oct 27, 2017 | 11:21 AM
Seizer's Avatar
Interesting did not know that. I figured since it was a recall for earlier models they just do the same for all year models. Good to know for future reference. Had mine done under recall since I have 2007. Did not have any issues like OP that's pretty wild that it may cause issues such as that.
Old Oct 28, 2017 | 08:10 AM
zstairlessone's Avatar
It is a multi cable ribbon connector that winds around as you turn your steering wheel. It allows electrical signals from the stalks, steering wheel controls, horn etc to get to the control module and allow the steering wheel to rotate around.
