New MyGIG Software Update RER-REW-REP 2.402 (I-Phone Fix!)
Yes..
I don't have a MAC but these are the instructions I received from a fellow member of JK forum.
For MAC's only!
Make sure to rename the disk to whatever the update is!!
when I downloaded the files whpony96 provided.. one of them was missing the version number. it needs to be like this for the System update =
RER_2.402
and this for the Gracenote update=
Gracenote
so again to recap
To update the navigation operating system you will need to download this file
http://www.mediafire.com/?klrbc2wmmug7967
1- Unzip it
2- you will see a folder. make sure that the folder title is RER_2.402 and that there are 2 files and 1 folder inside that "RER_2.402" folder.
3- Insert a CD
4- (Mac users only!) right click the RER_2.402 folder
5- you will see Burn "RER_2.402" to a disk. click it
6- double check the CD name. again make sure it's RER_2.402 or it will not run on your nav.
7- select the slowest speed to burn.
8- wait for it to finish.
9- start your Jeep and wait for the Mygig to load.
10- insert CD
11- wait for the screen to load. then select update.
12- DO NOT TOUCH ANYTHING! DO NOT TURN OFF YOUR JEEP! let it install and then once it's done it will restart.
13- Mygig will bring you back to that same screen you were prompt in step 11. at that point you can eject the CD and shut off your Jeep
same case with the Gracenotes
if you are updating your maps (you have to pay $215 for this)
it will take an hour and also you don't have to keep the Jeep on. you can let it download while on ignition.
For MAC's only!
RER_2.402
Gracenote
so again to recap
1- Unzip it
3- Insert a CD
10- insert CD
Originally Posted by whpony96
Yes..
For MAC's only!
RER_2.402
Gracenote
so again to recap
1- Unzip it
3- Insert a CD
10- insert CD
For MAC's only!
RER_2.402
Gracenote
so again to recap
1- Unzip it
3- Insert a CD
10- insert CD
Installation went perfect and most important of all it works GREAT with the iPhone 4 now. Bluetooth connection is quick and shows the caller ID on the MyGig like before. Thanks again whpony96 for your great work and effort for us.
my gig software update
i am too a little scared .dont want to mess anything up . i downloaded the file and burnt it to a disc. i dont have the nero burn software i have Roxio . seemed to burn fine .i did open the files and thay all seem to be intact .
whpony96 when you say you will not get a successful burn . when am i going to know this ? during the burning of the disc or during the installation of the software? just dont want to screw anything up. this jeep only has 600 miles on it !! my wife will never let live it down!! LOL
just did it successfully!!! I used Roxio also, it worked fine. At the end, the radio came on for a few seconds, then finally asked to update again, hit no, then eject.
