power window problem, any had this happen??
Old Oct 27, 2008 | 04:46 PM
fastrat350's Avatar
Default power window problem, any had this happen??
Well i just had peoblem with my power windows, my front windows wouldnt come down at all, it just happened right now and im posting thru my phone. I flipped thru the owners manual thinking it may have been a fuse but couldnt any info. The wierd part is only the front windows wouuldnt work, but i was able tolower the rear windows from the both the center stack and rear of the the console. But it fixed itself, i turned off my jeep and turned it back on and now they work......WTF. Anyone had this wierd problem or bug? i checked my wiring at the doors and all was fine. well gotta get back on the road
Old Oct 27, 2008 | 05:04 PM
ronzep's Avatar
My Windows have been flawless!
Old Oct 27, 2008 | 05:23 PM
tn_dodge's Avatar
We had the EXACT same thing happen to us, twice actually. It has been a while since it happened, and we did not do anything to try to get it fixed. It just hasn't come back. Nice, eh?
Old Oct 27, 2008 | 05:31 PM
fastrat350's Avatar
Could it be the Halloween spirits getting to my jeep lol
Old Oct 27, 2008 | 05:43 PM
rickc309's Avatar
I had the same thing happen a few times, I just shut the jeep off and restart. Always corrects itself, it must be a relay sticking.
Old Oct 27, 2008 | 05:49 PM
renegadelt1's Avatar
I know you likely have not fooled with them but check your connections where the doors plug in under the dash , Had a very similar problem on my friends rubi and found a corroded pin on the passenger side that stopped both windows from working.
Good luck.
Old Oct 27, 2008 | 05:58 PM
tibbar's Avatar
I too had it happen once, shut off the jeep and turned back on and it fixed it. Been fine so far.
Old Oct 30, 2008 | 04:31 PM
wadeh66's Avatar
Default Windows
I had this happen with 260 miles on my jeep. Same exact thing, front windows didn't work, back windows did, and then I turned it off and on again and they all worked fine. Hasn't happended again, but I only have 800 miles on my jeep and I don't drive it much.
Old Oct 30, 2008 | 05:02 PM
greenjeep's Avatar
Since shutting off the Jeep has solved the problem I wonder if its a interface problem with the computer... Beats me
Old Oct 30, 2008 | 05:56 PM
ronjenx's Avatar
Vehicles today are being designed by people who grew up on computers, instead of playing outside (not that there is anything wrong with that). They are used to having a "reboot" fix everything. Is it any wonder the most common fix for electrical control problems on the JK is a "reboot" of one form or another?
