Question on adding an amp.
Old Jun 13, 2011 | 09:43 AM
enzo319's Avatar
Originally Posted by apeezee
Yeah u have three RCA outputs. U do do NOT have to "bypass the infinity amp". don't let them charge u for that. Because u have that head unit it should be a standard install for them.
I agree with apeezee. IF you are using an aftermarket head unit and amp, hook that amp up and then run each channel to it's appropriate speaker. i would then disconnect the infinity amp. just unplug the wire harness (drivers side knee panel) after that go tell the stereo shop go f*** themselves.
Old Jun 13, 2011 | 01:58 PM
apeezee's Avatar
Ditto! These shops will do anything for a buck.
Old Jun 13, 2011 | 06:20 PM
stockrubi's Avatar
I agree with them, if head unit is already in no adapter is needed. Have you decided on the mounting location? I put mine under the glove box. You will love the extra power!
ID:	171569   Click image for larger version
Old Jun 14, 2011 | 08:12 AM
enzo319's Avatar
I seen that some guys put a 4 channel amp in the same location as the 'infinity' amp (driver side knee panel) u just have to figure out the dimensions of the new aftermatket amp and how u would mount it. I wanna say the amp people r using is a polk.
Old Jun 14, 2011 | 02:42 PM
outlikealight's Avatar
Thanks for all the replies and the ideas. I love the idea of the amp under the glove box. I will also check into putting it in the factory amp location.
Old Aug 24, 2011 | 12:48 PM
enzo319's Avatar
ludski
i have my factory HU. Single slot CD
Old Aug 26, 2011 | 11:20 AM
Originally Posted by ludski
the amp is the PDX 5 channel. fits in where amp stock amp is.
also OP, if youre selling your stock headunit and amp and amp harness and sub enclosure, let me know.
or any of the above.
I have the stock head unit and the sub. Hell you can have them if you pay for shipping. They are just sitting in my garage.
