Radio Reset
Old Nov 17, 2006 | 05:51 AM
MegaWalt's Avatar
Default Radio Reset
Has anyone else noticed that when you put both of the rear windows up at the same time that the radio powers off and on? :confused:
Old Nov 17, 2006 | 06:49 AM
jocrazy0's Avatar
Hmmmm. Methinks you have a wiring problem. I think I'd check the battery connections to verify that they are tight. (10mm sockect. Chintzy battery connectors at that! My battery posts are already covered with white lead oxide.)
BTW, I have tried rolling both mine (front AND rear) up/down simultaneously and my radio plays just fine.
You didn't mention it, but was this with the motor running or not? Either way, it (the radio reset) indicates a loose connection or other wiring problem.
Old Nov 17, 2006 | 10:45 AM
Ge99ne's Avatar
That happened to me for a half day after some very wet wheeling. It went away for me though.
Old Nov 20, 2006 | 12:46 PM
Ge99ne's Avatar
Well check that. It just happened today at lunch . Twice. It's not the kind of thing I would take time to get fixed at this point. If I was losing my staion presets, thought that would do it for me.
Old Nov 20, 2006 | 12:51 PM
MegaWalt's Avatar
Glad I'm not compltely alone. Have you checked your battery connections?
Old Nov 20, 2006 | 06:34 PM
marquis's Avatar
Default Radio resets
Check with the dealer to see if there are any service bulletins out for that.
Old Dec 6, 2006 | 10:26 AM
Ge99ne's Avatar
There is another thread on this topic that mentions a service bulliten. I mentioned it at the dealer today but the did nothing, since it wasn't acting up today.
