Seperates vs coaxial speakers in 2013 dash
Seperates will sound better due to better imaging. You want to have the tweeters mounted in a high location. Seperating the mids and tweets gives a much richer and spacious sound.
I have coaxials in the dash and components in the sound bar but moved the tweeters to the dash.
The crossovers have jumpers to adjust output levels somewhat to help balance the system, along with a 4 channel amp.
I think it sounds pretty good for a jeep, the coaxials do most of the work with dash tweeters to help "raise" the sound and then rear fill from the soundbar's mids works well especially without tweeters drawing you to the rear.
It took a while to get the amp gains and the crossover jumpers just right but worth the couple hours of tweaking.
Spend a little time and rearrange your set up so both speakers from you component set are in the FRONT speaker locations and move those coax speakers to you sound bar. This will give you ideal sound and imaging and you will be happy you did it.
Component speakers are typically better than coaxial speakers in vehicles for two main reasons:
For more details about component and coaxial speakers, click here.
- The external crossover provides better signal separation than a typical capacitor/inductor combo you see on coax's
- You can position the tweeter for better stereo imaging and overall sound quality
