Stereo upgrade
Old 02-18-2015, 04:20 PM
pickjones's Avatar
Originally Posted by immortalmetal
The double din units are taller and fatter than the stock stereo. There needs to be some modification to that "sub dash" bracket.
Originally Posted by Crush12JK
yes, the double din won't fit in the bracket. It needs to be removed to cut. The bracket holds the stock radio in place and has a screw on top to help hold the dash in place.
Good to know. Thanks guys!
Old 02-21-2015, 06:31 PM
star4862's Avatar
What bluetooth system did you end up using?
Old 02-22-2015, 01:29 PM
Crush12JK's Avatar
I'm using the kenwood bluetooth. The reason is that I want to use pandora with my phone. It won't let you use bluetooth connected to the u connect and send audio to the kenwood side for the integrated pandora control.
Old 02-22-2015, 03:43 PM
pazitive44's Avatar
Do you need to cut bracket inside the dash ..or does it come out easily to be cut on the Bench ?
The bracket on my 2010 , I had a very hard time removing it ...
Old 02-22-2015, 04:06 PM
Crush12JK's Avatar
It comes out with 2 screws. The two in the picture holding the cut bracket are the only ones holding it in. they are the same 7mm hex head screws found on the rest of the dash. I did the cutting on the bench and ground some of the sharp edges from cutting.
Dave
Old 02-23-2015, 07:58 PM
takiniteasy88's Avatar
I assume that using the Kenwood Bluetooth renders the steering wheel control for uconnect inoperable, is this correct?
Old 02-24-2015, 01:47 AM
immortalmetal's Avatar
If you get a pac rp4-ch11 module, it retains the steering wheel controls.
Old 02-24-2015, 05:40 AM
etl330's Avatar
What does the maestro do? My audio shop guy said it does different things but didn't really elaborate.
Old 02-24-2015, 10:04 AM
Probably the same thing, but he gets a cutback for selling them, so he's going to push his product. Lol... that's my guess
Old 02-24-2015, 11:20 AM
Crush12JK's Avatar
Using the Kenwood bluetooth does not render the phone and voice buttons useless with the maestro system. They can be programmed via computer to do anything. So, they could activate the phone via the kenwood. Or do something else.
Dave
Quick Reply: Stereo upgrade
