Stop/turn lights went bad
Old 09-17-2014, 08:32 PM
Slow_but_Sure's Avatar
Default Stop/turn lights went bad
So within one day both my tail lights lost stop/turn lights. Today i picked up new bulbs and changed them and no luck. I don't know what else could be the issue. Any ideas what to look for? Its a 17 month old jeep. Should i take it to the dealership? They should warrant this problem, right?
Old 09-18-2014, 04:26 AM
Jiblet's Avatar
Did you check the fuses?
There should be a diagram in your manual.
If it's more than bulbs/fuses then it should be covered under warranty.
Old 09-18-2014, 04:42 AM
Rob50lx's Avatar
Sounds like something is grounding out. Do you have a trailer plug? See if it is melted to the muffler.
Sent from my d2lte using Tapatalk
Old 09-18-2014, 07:05 AM
I looked at the manual and found the location of fuses. I"ll be checking the fuses today.
No, i don't have a trailer plug.
Old 09-18-2014, 08:24 AM
Former Vendor
TASCAPARTS's Avatar
If you cant find blown fuse and its only 17mos old.. I would be bringing in it.... why waste your time and money thatshould be cover under warranty..
Chris
Old 09-18-2014, 06:40 PM
Today i located fuse M1 and it looked fine to me. So i guess im taking this to the dealer. Its 2013 JKU
Old 09-18-2014, 07:39 PM
ronjenx's Avatar
The regular stop/rear turn lights have no fuses. (M1 is for the center high mounted stop light only.)
Either the TIPM isn't sending power to the stop/turn filaments, or there is a bad ground.
It will be covered under your warranty.
If you want to look at it before taking the Jeep to the dealer, with a meter or test lamp, look for power at one of the stop/turn pins in the bulb socket. That will tell you if it's a TIPM or ground problem.
Old 09-19-2014, 06:07 AM
Jiblet's Avatar
Originally Posted by ronjenx
The regular stop/rear turn lights have no fuses. (M1 is for the center high mounted stop light only.) Either the TIPM isn't sending power to the stop/turn filaments, or there is a bad ground. It will be covered under your warranty. If you want to look at it before taking the Jeep to the dealer, with a meter or test lamp, look for power at one of the stop/turn pins in the bulb socket. That will tell you if it's a TIPM or ground problem.
Interesting. I assumed m1, 17, 18 would've included the stop/turn lights. Good to know. Thx
Old 09-19-2014, 07:23 PM
I guess i will take it to the dealership at this point. I will update with more info on how it goes.
Thanks
Old 09-23-2014, 04:47 PM
No$4upgrades's Avatar
I'm have the same problem. Any luck? Mine is 2008
Quick Reply: Stop/turn lights went bad
