winch question.
Old Apr 19, 2009 | 05:35 PM
awdspider's Avatar
Default winch question.
is there any reason why i cant leave my controller plugged in? what are the negatives is doing this? thanks.
-shaun h
Old Apr 20, 2009 | 05:30 AM
You mean other than the fact that someone could steal it, use your winch, damage your winch, and run down your battery? Other than that, no reason you couldn't. lol
Old Apr 20, 2009 | 07:07 AM
awdspider's Avatar
The controller is mounted in my dash and it's hooked up to the ignition so it won't work unless the key is turned on.
Old Apr 20, 2009 | 07:09 AM
Offroadme's Avatar
thats a good idea.! never heard of anyone doing that.
Old Apr 20, 2009 | 07:21 AM
awdspider's Avatar
I'll post pics when I get home
Old Apr 20, 2009 | 07:47 AM
RedneckJeep's Avatar
Originally Posted by SONIC
(hummer with a winch what a joke )
Not really. Unless it's a H1, it probably needs it.
Old Apr 20, 2009 | 11:30 AM
If that's the case, then there doesn't seem to be any problem and most definitely post pics of how you've got it set up.
Old Apr 20, 2009 | 03:54 PM
awdspider's Avatar
well here is the controller, some may think it might be a bit cheesy but i did it this way so it would be pretty much dummy proof (incase the wifey gets behind the wheel). right now the solenoid box is behind the grill but i think im goona relocate it as well.
-shaun h
Old Apr 20, 2009 | 04:13 PM
seer1's Avatar
Think about putting in a second power toggle to really make it dummy proof. See 12voltguy.com's stuff it's pretty logically set up.
Muffins's Avatar
-shaun h
That looks good, do you have an additional controller for if you want to run the winch outside the Jeep?
