GR8WHITE 2.0 (But Actually Silver) (40’s, 8 lugs, stretched)
Old May 14, 2016 | 02:45 AM
GreatWhite JK's Avatar
That was quick... Now, I really need to find axles and once i do that I'm really gonna start buying parts.
Old May 14, 2016 | 04:44 AM
catahoula's Avatar
Looking forward to seeing this build. Looks like mine. Subscribed!
Old May 15, 2016 | 04:57 PM
dbrooks's Avatar
Damn! That was super fast!
Old May 17, 2016 | 06:41 AM
NJKURPat's Avatar
What's your plan for axles?
Old May 17, 2016 | 07:06 AM
TheDirtman's Avatar
Driving that set up 75 mph down the highway is going to be a stretch unless you only drive on flat highways. With your list of components I think you $20k budget is going to be blown as well.
You will want to add at least hydraulic assist steering if you plan on taking it off road and plan to be able to turn the wheel. 14" travel shocks/ori are going to much easier to fit with less frame relocation. If you really plan to run 16" and the double triangulated set up just cut the entire rear end off and tube it and do a full rear stretch. I don't see the point of doing a 3"-5" stretch on the rear. Move that rear axle back so you don't catch anything on ledge drop off's.
Old May 17, 2016 | 07:48 AM
front kingpin ford Dana 60
and 14 bolt rear
Old May 17, 2016 | 10:05 AM
Originally Posted by TheDirtman
Driving that set up 75 mph down the highway is going to be a stretch unless you only drive on flat highways. With your list of components I think you $20k budget is going to be blown as well. You will want to add at least hydraulic assist steering if you plan on taking it off road and plan to be able to turn the wheel. 14" travel shocks/ori are going to much easier to fit with less frame relocation. If you really plan to run 16" and the double triangulated set up just cut the entire rear end off and tube it and do a full rear stretch. I don't see the point of doing a 3"-5" stretch on the rear. Move that rear axle back so you don't catch anything on ledge drop off's.
Forget to put it up there but i am doing hydro assist... And yes i am aware of the amount of frame modifications and cutting I'm going to have to do. I have been considering back halfing this thing but I'm not sure yet. Are u running mostly stock modified frame out back?
Old May 17, 2016 | 10:16 AM
TheDirtman's Avatar
I kept some of the main frame rails. All the frame crossmembers are gone and replaced in more strategic locations. Even with 14" travel shocks you are going to have to cut out the rear main frame for shock clearance due to the large amount of axle rotation you are going to get and the big 40's.
Look up "Ringer" his build is close to what you are looking at doing although he has not done tons yet. He did a coiler triangulated 4 link with a custom fuel cell mounted like a TJ. He is in the 102-105" wheelbase range.
Old May 17, 2016 | 12:04 PM
I kept some of the main frame rails. All the frame crossmembers are gone and replaced in more strategic locations. Even with 14" travel shocks you are going to have to cut out the rear main frame for shock clearance due to the large amount of axle rotation you are going to get and the big 40's. Look up "Ringer" his build is close to what you are looking at doing although he has not done tons yet. He did a coiler triangulated 4 link with a custom fuel cell mounted like a TJ. He is in the 102-105" wheelbase range.
Ok thanks for the info! I know pretty well what I'm getting my self into as i have helped a friend mount a set of 14 rear and 12 front Ori's in his jk.
Old May 18, 2016 | 01:51 AM
Over the last couple days i have order a lot of parts. Beadlocks, Ori's, atlas 4 speed, all heims for control arms and steering. Here's the money log I am keeping so I can see how much I've spent on the jeep. (All stuff on that list is ordered) Dirtman is right... I'm definitely going over budget. (Disclaimer*** The rubi rails are on the jeep now and when i do the axle swap, I'm going to make boat sides.) Click image for larger version
