Airing Down - Airin Up Why/ How
I am curious,...
If you aren't having any traction issues on the terrain,...
Do you "always" air down?
I have been letting out about 8-10 psi to the mid to high 20's, but haven't been having any traction issues. Should I go lower to protect my tires from sharp rocks, or risk popping my beads in the middle of nowhere? I ask this because of my greater concern for the decrease in clearance I would have at a lower psi.
I run 14 PSI on my 33's. Generally the larger the tire the lower pressure you are able to run.
Just to stir the pot, I really like running at about 21-22 on my KMT2 285's. I had some issues with my Trailheads in that temperature effected them way too much. I ended up with the ARB deflator and really like it.
My Stock Sahara did ok when I was at Uwharrie in the mud without airing down in a few areas I had no traction at all but after airing down to about 15psi it was suprisingly better and for airing up it only took me oh about 2-3 seconds. Yes I said seconds. Being an avid paintballer I had a 4000 psi Nitrogen tank that was full and had gotten an Idea from a tool that Lowes sells. Well mine isn't regulated like the tool but works just as good with careful judgement and reasoning. IF YOU DON'T KNOW HOW TO DO IT DON'T BE STUPID AND TRY IT..... I had a coupler that fit the remote on a tank and connected it to an air chuck. Hmmmm opened the valve slowly and counted to 3 and had to let about 10 psi out of the tire. If you want to try this I reccomend using a nonlocking one to avoid over inflating the tire and I STRESS AGAIN, IF YOU DON'T KNOW HOW TO DO IT DON'T BE STUPID AND TRY IT..... Be Careful... They make regulated ones in several mags for around a few hundred bucks. or the one in lowes for about 80 something here are some links to them...
]http://www.lowes.com/lowes/lkn?action=productDetail&productId=166441-61735-J-6901-100&lpage=none
http://www.tellico4x4.com/product_info.php/products_id/28385
http://www.4wd.com/productdetails.aspx?partID=14192
Hope this helps out some
Last edited by toad; Jul 27, 2008 at 09:06 AM. Reason: Please refrain from direct links to non-sponsored vendors. :) Thank you!
Don't think anyone mentioned this yet -- if you're aired down, keep your speed below about 20 MPH. If you turn the wheel while going too fast, you can pop the tire off the rim and instantly lose all the air in the tire. Think "aired down = 4WD Low."
]http://www.4x4now.com/sfjun96.htm
Last edited by toad; Jul 27, 2008 at 09:09 AM. Reason: Please refrain from direct links to non-sponsored vendors. :) Thank you!
Stauns are ok but if your looking for an easier way with a more adjustability get this.
http://www.northridge4x4.com/proddet...d=ARB-DEFLATOR
So I wouldn't recommend this for those 2 reasons.
