how dangerous is pulling someone out?
i also agree
don't try to be a towing service--somehow it will end badly for you. lend a cell phone, give them a ride to a tow shop, or give a beer. if you break something or god forbid hurt someone accidentally you'll be left holding the bag.
It's not that "reverse gears aren't built as strong", it's the design of your ring and pinion that makes pulling someone out in reverse a very bad idea. It's too much to explain here, but your ring and pinion in your diffs are designed to withstand pretty substantial force moving forward, but in reverse the design actually works against itself and is exponentially more likely to fail under a heavy load. I'm probably a little over protective of my diffs, to the point if I am backing up a trailer, I do it in 4lo and very slowly. Long story short, don't try to pull out anything bigger than your Jeep, and even then, nothing buried very deep. Good luck, and have fun.
I go out to Pismo all the time and end up pulling people out every time I'm out there. Remember the Golden Rule. When you get stuck out there you want someone to come help you too. I have had no issues pulling people out of the sand there. I would not recommend using a tow strap to yank people out, there are a lot of people that do that. I go against the grain with pulling people out in reverse too, I do that all the time and have never had a problem even when I'm pulling them out in the wet sand and they're towing a trailer I've never had any problems. Be a pal and don't just drive by someone that's stuck, tow trucks are $300 bucks for them to just show up at Pismo and those guys don't seem to know what they're doing. Most of the time they just need a steady pull to get them out, if you can't get them out don't worry, as soon as you start working on getting them out you'll draw a crowd and someone will be happy to step in with a bigger truck.
I have found when off roading most people are pretty good people, with that said befor i hook up to anyone i talk with them for a few min. If they seem to be a pretty good person and dont act like a dumb a$$ i consider helping them out, but more than that i try and check to see if they know their rig. If they dont know their own rig then i either let someone else hook up to them or tell them i dont think my little jeep will not be much help at this time (just play the Jeep down, I know it is hard, because we know they are awesome).
The number one rule of offroading is know your equipment and its capabilities
if you are not comfterable with pulling them out then dont
Check their connection
I was trying to pull a guy out of a dry (mostly) lake bed and didn't check his connection to his Jeep. He talked like he knew what he was doing. After a couple pulls the tow strap and shackle broke free. Luckily I had the high ground and the shackle hit the hill and didn't fly into the back of my Jeep. He had connected the shackle to the trailer safety chain connection on his trailer hitch, which failed.
I lucked out. Check everything connected you your rig!
