Sway Bar Question
Sway Bar Question
Would you get more Articulation by disconnecting the sway bar links on a Rubicon? Or is the Electronic swaybar disconnect good enough? How much more would you get if there is more articulation to gain?
I haven't tried that on our Rubi but one of the guys on the forum did and Mel (Off Road Evolution) had him put on end links and use the Rubi elect DISCO so that's good enough for me. I think the Rubi Disco is good enough for most particularly if you have the correct length end links to compliment your lift.
Here's a couple of Rubi Disco end links connected pics:
Blonda at Green Day (Area BFE - Moab)
Mashed Potatos
Mashed Potatos
Holy Crap! I've never seen anyone do that! I've got Rubicon Express mono tubes for a 2-3.5 inch lift. I'm lifted 2.5. The links are correct for the lift. I might as well just use the electronic swaybar disconnect.
Bent sway bar links are a common occurance where the links are too short for your lift. Rule of thumb is to have your links long enough so that your sway bar is 5 to 10 degrees above horizontal. Many run much more than this.
I copied the following from another post:
To do this, look at the front sway bar from the side when the Jeep is on level ground. The sway bar should at a minimum be level with the ground or even slightly tilting up towards the rear of the Jeep. If the swaybar is tilting down, the links are too short. It doesn't mean that they will flip on you, but the risk is greater, especially when fully flexed. New links are inexpensive and easy to replace.
Here is a link to a photo that shows what it should look like.
http://project-jk.com/wpg2?g2_itemId=34171
my friend recently added a BDS 3" lift to his rubi. how would his electronic sway disconnect be affected? His concern is that by adding the lift that included a sway bar link that would in turn cause him to not fully utilize his electronic sway disconnect. Or do all rubicons come with a sway disconnect and a manual sway bar link? Sorry if my question is of ignorance. please let me know.
Speaking from experience, by using a ramp, there is no difference from using the e-locker or quick disconnect. However, my lift combo has very limited travel, compared to some of the others that are on this forum.
Some rubi owners do manually disconnect their sway bars. My personnel belief is that I paid for it, I'm goona use it.
