1 ton jk build
glad to see someone has a build thread on this. Im about to pull the trigger and start my 1 ton build. i feel like with all the money i spend fixing my damn axles i could have ordered rock jocks haha. do you have to do the spyntec kit to have wheel speed sensors?
Originally Posted by Unlimited5.7
Is it possible to run the factory tank and the sterling rear?
How are the road manors with the front 3 link?
Nice build!
Nice build!
When I was researching the Sterling install I emailed RedX08 and asked this same question. His advise was yes it can be done. If you Heat and Beat the tank corner and modify the sheild a little.
Check out jeep speed shop, they have a jk tone ring that will go on the hub of a 14 bolt. They also make a bracket that holds you sensor. This will make your pocket book happy. I could have gone with a unit bearing on the front 60, but i rather have a hub and spindle and just put new bearings in when i need to. I am not a fan of unit bearings.
