Aftermarket driveshaft
Old 10-16-2014, 06:55 AM
deepjeep13's Avatar
Default Aftermarket driveshaft
Who's running after market front or rear drive shafts or both? What are the pros and cons to what your running.
Old 10-16-2014, 07:48 AM
mattgt5's Avatar
Pro is no boot to tear and sling grease. Smaller diameter for better evap clearance. Also gives additional range if adjustment for you castor.
sent from my work leash
Old 10-16-2014, 05:39 PM
pjmjk's Avatar
Tom woods for the extra strength
Old 10-17-2014, 07:14 AM
BigSteve's Avatar
I run Adams Driveshafts front and rear. I have banged them both off the rocks without issue. I highly recommend them
Old 10-18-2014, 12:15 AM
Cascade Wanderer's Avatar
Ease of owner maintenance with fittings that can be greased.
Old 10-18-2014, 02:51 PM
genrec's Avatar
Noob here, so I see on aftermarket driveshafts ther re yoke ends and non? huh? can someone explain the benefit of a yoke over factory style?
Old 10-21-2014, 07:34 PM
deepjeep13's Avatar
The stock shafts are non serviceable and I seen guys blow diffs before yokes and that's the what you want. You want your yoke to blow before the diff has to
Old 10-22-2014, 05:02 AM
GrapplerJK's Avatar
Adams 1350 Rock Crawler Driveshaft. You cannot go wrong.
Quick Reply: Aftermarket driveshaft
