Billet heater knobs-
4WD will be carrying them, its made by (NCM), New Century Manufacturing
the factory knobs just pull off. but it isnt that easy.
I had to take the dash face place off and remove the heater control box. I ultimately got vice grips and pulled the factory ones off.. They are stuck on there!!
suppose you could try it without removing all that.l. but i didnt want to break any plastic trim.
the red dot glows at night.
Personally, I think that the whole aluminum panel dash kit is a bit much, I was thinking just the shift boot surround (like yours), shift/transfer case knob bezels, air vent bezels, and the climate control knobs would be just enough brightwork.
it snaps down of the front, and it kinda has a hinge on the back, You need to pry up and forward... it'll slide out..
You'll need to put your shifter in 2nd gear and pull up on the knob, it'll come off.
4wd carriers it for sure. thats where mines from... http://www.4wd.com/productdetails.aspx?pid=NCM600S
and the Qtech rep said they would be carrying one too. not sure when
