Billet heater knobs-
Old Mar 22, 2007 | 12:57 PM
Piginajeep's Avatar
Default Billet heater knobs-
Old Mar 22, 2007 | 01:38 PM
armycop's Avatar
Default Where did you find those?
Where did you find those??? I like that look, also would like to find silver bezels that go around the dash vents like one of the auto show JK's had.
Old Mar 22, 2007 | 01:40 PM
Piginajeep's Avatar
4WD will be carrying them, its made by (NCM), New Century Manufacturing
the factory knobs just pull off. but it isnt that easy.
I had to take the dash face place off and remove the heater control box. I ultimately got vice grips and pulled the factory ones off.. They are stuck on there!!
suppose you could try it without removing all that.l. but i didnt want to break any plastic trim.
the red dot glows at night.
Old Mar 22, 2007 | 01:42 PM
Piginajeep's Avatar
I hoping they make them too, It'll really complete the look. Ill see what I can find out.
Old Mar 22, 2007 | 04:53 PM
armycop's Avatar
Personally, I think that the whole aluminum panel dash kit is a bit much, I was thinking just the shift boot surround (like yours), shift/transfer case knob bezels, air vent bezels, and the climate control knobs would be just enough brightwork.
Old Mar 22, 2007 | 05:01 PM
fraynes1's Avatar
How do you get that shift boot surround off? I've tried but am afraid of breaking something
Old Mar 22, 2007 | 05:02 PM
Piginajeep's Avatar
Personally, I think that the whole aluminum panel dash kit is a bit much, .
I agree. Not sure where you got the whole panel idea from but that sounds like alot of aluminum
Old Mar 22, 2007 | 05:04 PM
Piginajeep's Avatar
get a plastic pry bar, and gently pry on the front off the shifter boot.
it snaps down of the front, and it kinda has a hinge on the back, You need to pry up and forward... it'll slide out..
You'll need to put your shifter in 2nd gear and pull up on the knob, it'll come off.
Old Mar 23, 2007 | 06:38 AM
nader's Avatar
where are you getting the billet shifter surround?
Old Mar 23, 2007 | 01:22 PM
Piginajeep's Avatar
4wd carriers it for sure. thats where mines from... http://www.4wd.com/productdetails.aspx?pid=NCM600S
and the Qtech rep said they would be carrying one too. not sure when
