Custom modular JK hardtop
#1291
JK8 Top
I don't think I am going to make the top modular. My son is the one who drives the jeep and he says he will not take the panels off. I also will be making a full soft top in the spring.[IMG][/IMG][IMG][/IMG][IMG][/IMG]
#1293
Edit: don't forget to wax the mold so the fiberglass doesn't stick to it .
#1296
I'm getting ready to start both the flatfender and the Retro Rhino projects, so things will begin to "unfold" soon, I'm setting up the projects in the workshop now. The fenders I'll use to derive an exact-fit bolt flange for the flat fenders. The JK and FSJ hoods will be sectioned and spliced to creat a master hood to make the mold for the Retro Rhino hood from. Using parts of both hoods I'll end up with a perfect fit on the JK with a hood that has the shape and curves of the original FSJ hood.
Haven't decided yet if I'll start a detailed thread somewhere on either project or if I'll just post occasional updates here.
#1297
Jk8 Top
Jeff, I was able to get a little done this week. The pieces directly behind the door are both in and the rear panels are in. I ended up using the West Systems six-10 epoxy to get everything set in place. My goal is to get the top together enough that I can remove it and turn it upside down to fiberglass the panels in from the inside. I am searching for the appropriate size glass before I make the "frame" for the glass. I would like to have the windows operable like your FJ40 window. From looking at all the pictures of various vehicles I think the old boxy extended cab S10 pickup window looks to be the right height. I cant tell if the rake to the window is appropriate yet. Once I find the windows I will section the window frames from the 4 door JK top so I can get them recessed to match the other windows. In the mean time I may fill the opening with a panel and cut the opening to fit. Do you think it would be better to try and lay the fiberglass mat while it is on the top or make a panel that can be trimmed to fit? If I scribe the profile of the openings I could cut a few bucks and cover it with 1/4" plywood or plexiglass to make the molds.
I can't thank you enough for providing so many detailed write-ups on the process. I would never had been brave enough to cut up two perfectly good tops to make one. I have owned the Jeep since 2012 and always wanted a full length hardtop and figured sooner or later someone out there would have made one but no such luck...so here I go.
#1298
Attachment 666213
Attachment 666213
Good luck.
#1299
For a while I've wanted to build a cargo rack that takes advantage of my HD tailgate hinges and tailgate reinforcement. I've been working on a prototype for the last few days - here are some photos of the completed prototype, which I'm calling the Overland Rack. The rack attaches to the hinges and tailgate reinforcement and swings with the tailgate. It's designed to clear at least a 37" spare (mine is only a 32).
A Hi-Lift can be mounted across the back, and this morning's sewing project can also be seen in the above photos - an ACU camo cover to protect the jack mechanism from the elements. The ACU camo "Tactical Spare Cover" was another recent sewing project.
The rack also has Molle grids on both sides, and also bolt holes for Rotopax or similar liquid containers on the sides.
In matching ACU camo, a Molle military surplus "sustainment pouch" on the driver's side (there are also two on the Tactical Spare Cover):
A 2.5-gallon Rubican on the passenger side:
The rack has a plug-and-play third brake light - the plug is compatible with the factory third brake light plug, so it just plugs right in to the factory wiring.
It also has a step for climbing up on top, so here's a video of the 6'6", 225-lb. gorilla test I usually do for projects like these:
http://www.youtube.com/watch?v=xpPdmDdLaXY The complete rack weighs just under 39 pounds. Light weight + high load carrying capacity were important design goals for this project, I don't believe in using up cargo capacity by having unnecessarily heavy cargo racks.
#1300
^^ that's awesome Jeff. I don't know that I've got the creativity that you do but if I did, I'd like to think I would create these kinds of things.
