Custom modular JK hardtop
#292
I've worked up an animation showing the various Safari Cab side configurations I'm thinking about. Shown in the anim (it might take a few seconds to load) are the full soft side configuration (sides and back), both rolled up and rolled down; a soft sides/hard rear configuration with the barn door off and on, and the full hard side configuration with slider windows.
I can post any of the images separately if anyone wants to see them as still images or has questions/comments/criticisms of any of the configurations and wants to discuss them further.
#294
I did do some new product testing at Moab, here's a shot of my LJ with a pre-production "Excursion Rack", which is holding the cooler with our lunch:
It's a handy fold-up rack that mounts on the spare, and also folds up when not in use. It can be used on the JK as well as the TJ.
Also I've routed my trip home so I can stop by the RV window company I'm working with to get the sliders made for the JK half door uppers, so it's not just a road trip, I'm making progress on some other products while on this trip .
#296
I happened to be doing some fit testing of the rack on a different Jeep today so I checked the range of tire sizes the rack should fit - should go on anything up to a 13.50 section width tire, for example a 37x13.50. On the small end, it'll work fine on a 215/75-15 on a TJ, so pretty much any reasonable tire size on a Wrangler is fine.
Also today was testing installs of the production heavy-duty hinges plus pre-production versions of the Hi-lift carrier and the CB antenna mount that go on the hinges...
#300
