Old Sep 11, 2012 | 02:11 PM
  #1411
Wendy.Jeepchick's Avatar
Originally Posted by JKCobra
I put a centerforce clutch in my 2 dr manaul JK and it did make a huge difference. But I was also forced to because of the 5 lb of mud in the old one...
I run 35s (Duratracs) on an auto 4 dr sahara. I don't do a ton of offroading, more a daily driver, but I have kept an eye on it for sagging. Thankfully I didnt really see any issues over the last year and just added gussets to make sure I avoid it in the future.
On your previous comment regarding ride quality with a lift, I had the same issues with previous lifts and just upgraded to the AEV 3.5 with the reservoir shocks. The ride is better than stock!
Yep...5 lbs. of mud will do it every time!
Old Sep 11, 2012 | 04:32 PM
  #1412
greggnj's Avatar
Default Outback Adventures Trailgater
Originally Posted by BFGJKTuna
I also recently installed the Outback Adventures Trailgater. Yes--expensive, but extremely well made. The cutting board is now bamboo and the shcokes have been replaced with cables for added strength,
Does anybody know if works with a subwoofer? Didn't see it on their website...
(away on business right now so I can't look in my Jeep)
Old Sep 11, 2012 | 04:39 PM
  #1413
Mgimelli's Avatar
Love all the exposition jeep in this thread
Old Sep 11, 2012 | 05:18 PM
  #1414
maine07jk's Avatar
I figured this would be the best place to ask this. I need to sleep in the 4DR for two nights. What have people used in the back to fill the crack when you fold the seats down? I broke my back last year when I slept in it for one night!
Old Sep 11, 2012 | 05:30 PM
  #1415
ShakyJake's Avatar
Build a platform...many threads around on this, flattens rear with added benefit of storage or equipment (air pump/tank, subwoofer, etc) underneath. You could also go with just an SUV air matress, but will still not be flat. Best option I found was a RTT, but probably not worth it for just 2 nights, unless you are with someone incredibly special. If it's just you, go for an air mattress, a pint of whisky, and be done with it.
Old Sep 12, 2012 | 12:42 AM
  #1416
Mark Doiron's Avatar
Originally Posted by Patryk
Speaking of 35s on non jkur, hows everyone holding up on 35s that does not have a rubi?
Friend of mine just shot his D30 while wheeling in Palo Duro Canyon. But, strangely enough, it wasn't the usual suspect, the small pinion gear. It was the ring gear the broke some teeth.
Old Sep 12, 2012 | 12:48 AM
  #1417
Originally Posted by texas_jk
What roof rack is that?
As someone else mentioned, MBRP. And MBRP basket. I also have the MBRP front extension, but need to modify it to work with the AEV snorkel. FYI, the MBRP rack I have is not compatible with the later models JKs (the ones with the larger window glass--10 and up, I think).
Old Sep 12, 2012 | 12:50 AM
  #1418
Originally Posted by Wendy.Jeepchick
... Now on to the gorgeous pics that Mark is posting...
There are two Marks here. And we both like to share credit for remarks like that. LOL.
Old Sep 12, 2012 | 12:52 AM
  #1419
Originally Posted by BLK07
? For expo. Trips/ minimal offroad. Whats the best bet 33-35 in tires. Are 35s really needed? I have 35s on now. But contemplating on a set of 33s for my new Wrangler.
I think one of the best compromise tires out there (road and off-road travel, which typifies overlanding for most of us) is the Goodyear Duratrac. I started with stock SRAs, then Dick Cepek FC IIs, and not the Duratracs. The Duratracs have held up well in snow and ice, rain, mud, rocks, dry pavement. They are just a great, overall tire.
Old Sep 12, 2012 | 12:56 AM
  #1420
Surprisingly, my Jeep went through this and got stuck. I used the clutch to rock it about 12-15 times before I finally got it out of the hole. About 10K miles later when I changed the clutch (bad throwout bearing), the inside of the bell housing was clean as a whistle. This is contrary to the mantra "never shift in water because it will be sucked into the housing and ruin your clutch." Go figure ...
