Old Oct 8, 2012 | 04:36 PM
  #1601
MIZZOU's Avatar
Give me three days in the wilderness over playing on the rocks for a few hours any week of the year ...
Where did you get that rear gate fold down shelf. Been looking for something to clean my trout/birds on. That is SWEET!
Old Oct 8, 2012 | 05:35 PM
  #1602
goncalo's Avatar
Originally Posted by jckid
I finally got my trailer off the beaten path last month. I picked a couple of easy Jeep trails for the trial run. It handled well, although we did add a third load bar under the tent after nearly loosing it on the trail! We McGyver'd it to make it home, but it gave us the opportunity to sleep in the back of the two-door for a night, so now we know we can. And the only thing that made it uncomfortable was the lack of a mattress.
I really like your jeep its awesome. I'm working on my own 2 door overland jeep. I don't see enough of these builds but I completely understand why. I just wanted to comment since it was so cool
Old Oct 9, 2012 | 01:36 AM
  #1603
owntmeal4life's Avatar
Ditto gonna build an off road teardrop to make up for my lack of space for y 2dr
Old Oct 9, 2012 | 01:46 AM
  #1604
Kojack's Avatar
A bunch of companies make them, also, there is a guy that sells them on eBay, and they are great.
Old Oct 9, 2012 | 05:58 AM
  #1605
Mark Doiron's Avatar
Mine, which I believe is the only one to come with a cutting board (now bamboo, however) came from Outback Adventure Products. It's called the JK Trailgater. It is the most expensive of the lot. At least one company makes one with a small, upper shelf that may come in handy for some users.
Old Oct 9, 2012 | 10:33 AM
  #1606
mficarelli / LandShark's Avatar
First off, non-CARB compliant cans are no longer sold new in the U.S. I'm not saying you can't find them, but it is illegal to import them into the country. All cans sold must be CARB complaint throughout the entire country. That means that wretched nozzle that you must push and pull all at the same time while holding 35 pounds worth of gas at an awkward angle trying to get it to flow into the refuel port. Awkward is an understatement. So, possible couple answers:
1. Find old "Blitz-style" cans and refurbish as necessary.
2. Buy the CARB-complaint cans and live with it's sucky nozzle.
3. Buy the CARB-compliant cans and use a siphon hose. This is a very elegant solution, it really is, if your cans are mounted high enough for siphoning to work. You can buy the siphon hose here--it works by pumping it up and down quickly inside the can four or five strokes, then fuel magically flows. No sucking involved. okoffroad.com/stuff-siphon.htm
4. Find a source for the non-CARB cans. They aren't cheap. Expect to pay $100-150 for new ones.
BTW: I recommend the WEDCO cans (also sold as Briggs and Stratton) without the seam around the edge at the bottom (which the can you linked has, BTW). The major problem with them is that the plastic cap is not permanently attached. I've had kids in the neighborhood remove them and throw them around the 'hood, losing one. After phone calls to WEDCO, Briggs and Stratton, and Plastic Manufacturing, Inc (who makes the cap for those two companies), I came to the conclusion that it is no longer possible to buy the caps (they used to sell it in a set with a new nozzle). I've tried caps for other cans, including plastic ones, but they have a different thread pitch. If you lose a cap, you get to buy a new can. I've since taken option 4 above, and have the real-deal in cans. The metal cap is affixed by a hinge to the can. And, the way it mounts in my jerry can rack, it's not possible for someone to open the cap without first cutting the lock off of the rack. So, the fuel inside is better protected from mischief. Don't ask where I picked up the cans--my source is dry.
Mark,
That siphon hose is a great idea, I'm going to use that, thanks.
Mike
Old Oct 9, 2012 | 10:54 AM
  #1607
I like your trailer, did you build it or is it a military trailer? I built my as a 4'x4' box for the tight forests in Northern California, unfortunately I can't carry as much. It's still in the protype phase, so it's unpainted I keep changing things as I use it, finding out what works and what doesn't. I think I will add decks at the sides and front like yours. I also want to build a lid like yours. Did you build it? If so, what was the frame built from? Tubing, angle, channel, etc. Thanks for sharing your trailer, here's mine during a scuba diving weekend.
Old Oct 9, 2012 | 02:45 PM
  #1608
jckid's Avatar
Thanks! I'm pretty happy with my setup now. I had a 4-dr. before, and I wouldn't trade back now. The 2-dr. is pretty capable with just 33's and a mild lift. If I had another 4-dr. I would want at least 35's, a bigger lift, regearing, and probably more. The way I figure it I have the same amount of money in the Jeep and the trailer as I"d have if I had a fully equipped 4-dr. with no trailer. This setup gives me more options. I'll be using the trailer for base camping and mild expedition/off-road travel. For rougher trails, we'll sleep in the 2-dr. or tent.
My trailer is new and made by Sierra 4x4 Trailers. Check out their website, and you'll probably get some good ideas for your trailer. They build just lids too. It looks like you're off to a good start. We're still kind of customizing our setup as we figure out what we need. We plan to add Rotopax cans, maybe a hi-lift jack, and a motorcycle mount to carry our Honda Trail 110 as emergency transportation.
Old Oct 10, 2012 | 02:42 PM
  #1609
m(a)ce's Avatar
Originally Posted by NFRs2000NYC
Wow that looks awesome? How would you describe these "roads"? More moab or more dirt road driveway?
the roads seem to range but the 2 times I've been up there they far exceed fire roads. the scenery is great and I'd say they're equivalent to harder green trails with some blue obstacles. There are occasional pucker moments since the trails aren't groomed.
Originally Posted by deeker
WV has a bunch of those "Unmaintained Roads" as well. Great adventure to get an old map - or current map if they are complete enough - and see what you can uncover on some of the old roads. Many cross through farm fields and across what would otherwise be private land. Be polite and close any gates behind you. Be careful of those who would think you are trespassing and want to escort you off their land with the support of their shotgun...
Thanks for the good pictures.
Exactly. These trails are public but people need to be respective of the property owners/private land. Keep these open by traveling in small groups, using common sense, friendly smiles/waves to locals & following Tread Lightly principles.
Glad you liked the couple pics. Next time I'll use the Go Pro too.
Originally Posted by old fart
after we get our camping gear,i would love to make that trip with you guys next spring,summer or fall....the boss is not into winter camping.
they r some nice pics.lover ur 4dr....that is the build route i am taking....i hope!!
Originally Posted by greggnj
X2. Looks like a great trip. Sorry I missed that. This year it will be on my calendar as soon as the date set.
Awesome guys. It's a fun time. Hope you can make it!
Old Oct 10, 2012 | 02:51 PM
  #1610
m(a)ce's Avatar
trailer looks great!
how was your buying experience?
