Would running it via relay close to the battery mitigate the hazard at all? As long as the relay does not fail, with the switch off the line going through the Jeep to the inverter would essentially be dead. (Learning, not trying to actually circumvent your knowledge or safety)
th05.deviantart.net/fs70/PRE/i/2012/130/1/c/extreme_ironing_by_kumori_kinya-d4zb6jo.png
Pure sine wave for the most fussy gear, and it has a GFCI outlet to automatically and quickly turn off power in the event of a short (such as if water works its way to where it shouldn't be) ...
xantrex.com/power-products/power-inverters/prowatt-sw.aspx
It is $190 on Amazon. I think I'm going to add this to my never ending future upgrade list.
I've noticed that the usb port on the rhw is significantly better than the in the console......not sure about a tablet but charge time on an I- phone is shorter plugged to the dash usb if that is of any use...
Initial information that isn't accurate. "With my 2012 Nexus 7 the USB port is sufficient to maintain and slightly charge while in use. I'm using the same app as you Mark (Backcountry Navigator Pro) and has set my tablet to never turn off automatically. It charges so slow that I wouldn't ever try to use the tablet for navigation and charge it from a very low battery level but I've managed day trips with heavy use and been able to maintain a full battery over 8+ hours.
**I only have one USB which is under the center arm rest.**"
Jeep is coming along, about 6 months ago I put a 2.5 MetalCloak lift and M.O.R.E skid plate. Over the last 10 months, I have been looking for parts in Criaglist & forums.
3 months ago, I added a Spod, on board air, reclined the rear seat
Finally found the AEV bumpers (front bumper, which plate & skid =$800) (rear bumper & tire carrier = $1100) & came across some AEV wheels (7 = $950). Then I added the winch, fuel caddy & backup camera & KC Daylighters.
Plan to add rear seat heaters, a rear deck, & tail gate table soon.
Later a high lift jack & pull pal.
Yes, the standard 12v ports are really just trickle charge and will maintain the charge with normal usage but barely up the charge in the battery, whereas a decent dedicated inverter will charge in a similar fashion to you wall socket. I have my iPad mounted in cab and charge lead goes to the 12v socket. If the iPad is switched on it will maintain battery at the per cent age it's at when I start. If I switch the iPad off it will increase the per cent age by a couple of per cent per hour.
Since you're tryin' to save $$ you should make your own tailgate table.
Here's mine...
Attachment 534781Attachment 534782Attachment 534783Attachment 534784
Here's mine...
