Old Nov 25, 2016 | 01:59 PM
  #6091
KBennett2007's Avatar
Vet Army
I like ARB products, and that's probably the one that most folks have. But I replaced mine with this one, and the difference is huge. Not only does this one have materials for more difficult repairs (such as a Baja patch), but the top-notch quality of the tools is immediately obvious upon opening it up and just looking. Pricey, and only you can decide if you wish to spend that much, but I highly recommend for serious overlanders.
https://www.extremeoutback.com/produ...3+001-009.html
Thanks Mark, I think I'll take your advice.
Old Dec 4, 2016 | 05:41 PM
  #6092
NMBruce's Avatar
thats what I have been carrying
Old Dec 5, 2016 | 09:59 AM
  #6093
JGBOffRoad's Avatar
Default Pacific NW Adventure ready!!
ID:	662200 Click image for larger version
ID:	662202 Click image for larger version
Its a work in process, but we are happy with it!!
Old Dec 8, 2016 | 04:09 PM
  #6094
QPDO's Avatar
A far cry from many of the units on here... but a step in the right direction. Just had my AEV 4.5" DualSport RS kit installed, my AEV tire carrier installed, going to install my under-hood ARB compressor kit and have it wired into my sPod, build my rear shelf in preparation for the final placement and setup of my ARB 50qt fridge. Next on the list is the JCR Vanguard and Warn Zeon 10S.
Old Dec 9, 2016 | 07:01 AM
  #6095
socal73's Avatar
Looks very nice and clean! Congrats and great job !
Old Dec 9, 2016 | 07:02 AM
  #6096
socal73's Avatar
Like to see the rear shelf when complete!
Old Dec 11, 2016 | 05:05 PM
  #6097
QPDO's Avatar
Thanks! Clean and simple is my moto for the Jeep
Unless someone can convince me otherwise (I.E. tell me this is a terrible idea, wont work, or should be modified in a different way), I'm going to try something that I haven't seen yet for a rear shelf. I have hookup for 1/4" aluminum sheeting, so I was thinking of building something sleek, strong, and easily removable. My planned attachment/securement points are the 6x hard top frame mounting bolts. Break the sheet at angles to maximize shelf area/minimize dead space, while protecting the plastics from cargo. Center floor support at the base (simply rests, does not bolt down), up to the hinge for the access panel to the jack/etc. Approximately 6" of room under the shelf for a Rubbermaid container or two for supplies/recovery gear. I'd have to make a couple mock-ups with cardboard, but this is the general idea:
OR
Old Dec 12, 2016 | 01:11 AM
  #6098
Mark Doiron's Avatar
OR
That's a lot of work; will be interested to see how it turns out. I used a 3/16" sheet of aluminum cut to the exact shape of the bottom of the rear cargo area, then broken at the front of it to keep it from bending under load. Put nutserts into the stock Jeep floor, then screws through the aluminum plate to hold it in place. After that, threaded holes in the aluminum plate are used to hold my Tembo Tusk fridge slide and SoCal storage drawer in place. I'll see if I can find a few pics.
EDIT: Here's the album ...
https://www.facebook.com/media/set/?...1&l=493982bd8c
And here's my bottom plate ...
Old Dec 12, 2016 | 05:31 AM
  #6099
QPDO's Avatar
Slick! Thanks for your input, Mark. Your rig and your adventure videos are what got me into this whole overland stuff so your input means a lot. To avoid over complicating things and to stick to the KISS rule, how about the following modifications? Instead of one solid pieces, make the bottom support pieces separate cuts/breaks similar to the ORV brackets:
ORV Support Brackets:
Old Dec 12, 2016 | 08:07 AM
  #6100
That looks pretty cool. I figure you've got plans for those exact spaces, just as I did for mine.
