IPF lights
Old 07-13-2010, 08:04 AM
azrwilkinson's Avatar
Originally Posted by YingYang
Stock
Stock & IPF Side by Side
IPF's
Looks great. My friend has those as well...really bright!
Old 07-13-2010, 09:50 AM
bkw
bkw's Avatar
Blue bulbs..
Can't stand em. Will be going for a set of Silverstar Ultras soon.
Old 07-13-2010, 10:41 AM
JKilpatrick's Avatar
Thumbs up
Thanks, azrwilkinson. Now my minds made up, they're definitely on the list.
Old 07-13-2010, 10:45 AM
Pluke the 2's Avatar
even though ipf's are a lot better then stock. I would go for some xenon HID's instead, if I had to re-do it.
Old 07-13-2010, 01:37 PM
IcyFridge's Avatar
There is no way the stock lights are that white! They're like a flashlight. My mag lite puts out whiter light than that!
I had blue X4 fatboys and they were the best, then they started to get old and dim, so I went HIDs. (only do this if you live in the country, cuz it does glare!)
If my gf doesn't like the IPF bulbs, I can always get her a set of silverstar ultras and they would look similar anyways.
Old 04-26-2011, 06:08 PM
sringer's Avatar
so is what im gathering that the "blue" ipf's put out a white light not a blue light?
Old 04-26-2011, 06:38 PM
20JK10's Avatar
My headlights came with the blue lights. I couldn't see a damn thing with them, especially when it was wet out. I swapped them out for Sylvania Xtra Vision [slightly whiter and brighter then the regular replacements], and it was a night and day difference. I could finally see the road and the lines.
Old 04-27-2011, 03:04 AM
DCJEEP's Avatar
For some stupid reason my ipf lights keep burning bulbs. I've been through two on my pass side in a couple weeks. Wtf.
Old 04-27-2011, 03:49 AM
Mark Doiron's Avatar
Yes, it is a very white light. To get that they have a bit of blue tinting on the bulb that is easily seen in the reflector in the daytime (bkw's pic above shows that blue reflection clearly--it isn't an artifact of the photo). If you're into that ricer look, go for the blue IPFs. Otherwise, get the white. Or do what I did and use some cheap bulbs and be delighted with the results.
Old 04-27-2011, 04:18 AM
IcyFridge's Avatar
Trust me on this... any bulb will be twice as bright with a proper wiring harness. I ran one with my Susquehanna E-Code hellas and silverstar bulbs were nearly as bright as some HID setups. Sure, the IPF has a nicer output and cutoff than the stockers, but the bulb is not putting out as much light as it could be.
Thinking about putting a harness on my girl's JK to work with her IPFs.
Quick Reply: IPF lights
