Laugh now but envy my 1/2 doors later...
Jim
I see what you are saying about the uppers. This probably won't help but here you go.
This is a 1" grid. I can give the CAD file to anyone that wants it. You could print it out and cut the shape if you want. The fronts are slightly bigger than 36" so they would have to be plotted sideways.
I finally got the frame cut and hope to weld it tonight. Does anyone know if the sheet metal will distort/warp when I weld it to the tubing? The sheet metal is 18gu and the tubing is 14gu.
First post updated...
you should tack weld first,before you finish welds,BTW the flat metal does not have the bow(jk body has some curves-not square),the skin should go over nicely shaped "base platform",the tubing is huge(2x2 ? 14gauge)
,the final half door is going to be heavier then stock full door...? i am not criticizing,just a suggestion
without DIY's there is no jeep
,the final half door is going to be heavier then stock full door...? i am not criticizing,just a suggestionwithout DIY's there is no jeep
you should tack weld first,before you finish welds,BTW the flat metal does not have the bow(JFK body has some curves-not square),the skin should go over nicely shaped "base platform",the tubing is huge(X ? gauger)
without Doy's there is no jeep:thumb sup:
,the final half door is going to be heavier then stock full door...? i am not criticizing,just a suggestionwithout Doy's there is no jeep:thumb sup:
The tubing is 1X2 (yes, overkill but it was cheap!!!) and the total weight is surprisingly light. I laid all the pieces on the skin to see how heavy it is going to be and it FEELS quite a bit lighter than my buddies OEM 1/2 doors. It would have been cool to use 1X1.5 aluminum tubing and 3/16" aluminum skin but I don't know anyone that welds aluminum and it was a LOT more expensive.Thanks for the tips!!!
