mcmahonbj JK Build Thread
Old Mar 22, 2014 | 05:53 AM
mcmahonbj's Avatar
Default mcmahonbj JK Build Thread
For starters I would like to shout out to Eric Miles @ www.offroadelements.com such an awesome guy always there to answer my questions at all hours and exceptional and over the top customer service. Any chance I get I order from him even if it cost a couple extra bucks his service is worth more than that. About 90% of the parts I've ordered are through him.
2008 Jeep Wrangler X with Rubicon wheels
-2 Door
-6-Speed
-42,000 miles
-Stone White
Installed:
Daystar Dash Panel Kit
Rampage Black Fuel Door Cover
Rugged Ridge Black Handle Wrap Kit (REMOVING)
Rugged Ridge Front Floor Mats
Removed Front Carpet
Broadway Rearview Mirror (concave)
AntennaX 13" Antenna
RK 2.5" Stock Mod System (actually netted 3.5")
--(x2) Long Travel Progressive Rate Front Coil Springs
--(x2) Long Travel Linear Rear Coil Springs
--(x2) Front Sway Bar Disco Extended Links
--(x2) RK 2" Front Bump Stops
--(x2) RK 2" Rear Bump Stops
--(x4) Bilstein 5100 Shocks
Crown SS Brake Line Kit 0-6"
RK Adjustable Front Track Bar
RK Rear Track Bar Bracket (welded)
T-Mat Trunk Mat Custom Kit
Tinted Mopar Soft Top Windows
30% Front Window Tint
Nitto 285/70R17 Terra Grapplers (x4) (SELLING)
Rough Country Front Track Bar Bracket
DynoMax Evolution Competition Exhaust
10" Dual Subwoofer
Dual Amp
Wade In-Channel Window Vent Visors
Optima Yellow Top Battery
Alpine CDE-143BT
Suprise Straps Paracord Grab Handles (black)
Dana 30 JK Carrier Case (3.73 Up)
Lube Locker Dana 30 Differential Cover Gasket
Lube Locker Dana 44 Differential Cover Gasket
Nitro Gear 4.88 Package (front/rear)
EVO MFG Rock Star Skids/Relocation Brackets
TeraFlex Dana 30 Differential Cover
TeraFlex Dana 44 Differential Cover
TeraFlex Front Axle Sleeves
TeraFlex Front Axle Gusset Kit
TeraFlex Rear Sway Bar Extended Link
ORE Black Lug Nut/Lock Kit (Inc. Spare)
Superchip Flashcal (forum member)
ACE Bolt-On Rock Sliders
ACE Pro Series Front Bumper Bull Bar
--21.5" Lifetime LED Single Row Bar
ACE Pro Series Rear Bumper w/ Tire Carrier
--(x2) 7.5" Lifetime LED Single Row Bar
--ACE Jerry Can/Rotopax Mount
--ACE Slant Back Tire Carrier Kit (won't use)
Truck-Lite LED Headlights Headlights w/ Anti-Flicker Harness and Self-Defrosting Military Lenses
Offroad Elements Superior Grill Mesh*
Vector Offroad UFOs (tailgate)
ATX Slab Beadlocks 17x9 (x5)
ACE Wide Tubular Fenders (Black)
Rugged Ridge Hood Lock Kit
Goodyear Wrangler MTR Kevlar 37x12.50R17 (x5)
Rubicon "Take-Off" Rails
12voltguy 6-Switch Panel
ACE Rear Cargo Basket
OTRATTW Switches (Green/Red Light)
--JK Bumper Light Bar (front LED bar)
--Windshield Light Bar (to come)
--Rock Lights (to come)
--JK Rear Lights (rear LED bar)
--Air Compressor
Angry Offroad Power Distro Box
Spiderwebshade Trailmesh SW1-2D
ARB Compressor Special (CKMA12, Hose Kit, Inflator with Gauge, JK Mount Bracket)
Trek Armor Front Seat Covers (Black/Black)
Quadratec Extreme Duty Battery Terminals
Rock Hard License Plate Relocation Bracket w/ LED Light*
Vector Offroad UFOs (hood)
Smittybilt D-Rings (x4) (black)
Kicker 40CS654 6.5" Coaxial Speakers (x2 pairs)
--Adapter Brackets
--Speaker Wiring Harness
PSC Fire Extinguisher Holder (Black) (Roll Bar)
Extended Axle Breather Hoses
RECON 10,500 Winch Premium Kit
--Synthetic Rope
--Wireless Remote
--10' Tree Saver/Tow Strap
--Snatch Block
--x2 D-Rings
--Waterproof Cover
--Polished Hawse
Factor 55 Pro Link (Red)
Factor 55 Winch Lock
Poison Spyder Aluminum Hawse Fairlead (Black)*
Smittybilt GEAR Tailgate Cover (Black)
Rugged Ridge Tow Hitch Wiring Harness
Hopkins Mag-Flat Magnetic Harness Bracket P/N: 48095
Rugged Ridge Aluminum Hood Latch (black)
Bilstein Steering Stab.
Synergy Steering Stab. Clamp
Cobra 18wx II CB Radio
Fire Extinguishers (x2)
ARB Medium Recovery Bag
Daystar D-Ring Isolators (x2 pairs) (black)
ARB 30' Snatch Strap 17,500
AWT Install:
Rock Ridge LED Tail Light Conversion (Red Lenses)
Rugged Ridge Lower Center Switch Panel (SELLING)
Adams Driveshafts (front)
Olympus Off Road 18W Bolt Rock Lights (x3 Pairs)
12voltguy In-Cab Winch Switch Panel w/ Wiring Kit
Rock Ridge Tail Light Conversion Harness's
EVO MFG Drag Link Flip Kit
Planned
-Hilift 48" Jack
-CB Antenna Setup (JK-1 Style)
-Sickspeed Knob Set (black)
-RK HD Tie Rod
-RK Adjustable Control Arms or Long Arm Kit
-RK HD Rear Track Bar
-U POL Raptor Line Jeep Exterior (white)
-Monstaliner Jeep Interior (black) (front 1/2 tub and door sills)
-Rockhard Bolt-In Sport Cage (black)
-Body Armor Trail Half Doors
-Body Armor Trail Side Mirrors
-Safari Strap Extended Warrior Cage Net
-PSC Hood Louver (black)
-Rotopax Gas Cans 2 gallon (x2)
-RIPP Gen 2 S/C Kit
-EVO MFG Protek Skid System
-Windshield Header Replacement (updated metal)
-Smittybilt RUT Shovel
-ARB Tire Repair Kit
-LED Interior Dome Light
-Ten Factory Front Axle Shafts
-Ten Factory Rear Axle Shafts
-TeraFlex Pro44 Front Axle Housing
-Adams Driveshafts (rear)
-Synergy HD Ball Joints
-Lifetime LED Single Row 50" Bar
-Rock Slide Engineering 50" Light Bar Mount
-Recon Front Smoked Running Lights
-Synergy HD Tie Rod Ends
-Hilift Jack Mount (unknown mount setup)
-TeraFlex Universal Mud Flap Kit
-Rugged Ridge Door/Hood Hinge Covers (black) (x3 pairs)
-Rock Slide Engineering Side Body Armor
-EBC Extra Duty Brake Pads
-OE Rotors (Autozone)
-ARB Air Lockers (rear)
-Aussie Locker (front)
Old Mar 22, 2014 | 05:54 AM
mcmahonbj's Avatar
On the Way Home:
First Mods:
AntennaX 13" installed
Tires arrived
mcmahonbj's Avatar
PlastiDip Succeses.
Old Mar 22, 2014 | 05:55 AM
mcmahonbj's Avatar
Surprise Straps installed!! Such an amazing product, I did not expect them to be so heavy duty. Exceeded my expectations for sure and install took 5 minutes tops!
mcmahonbj's Avatar
Old Mar 22, 2014 | 05:56 AM
mcmahonbj's Avatar
Gotta change the oil still on her
Rear end setup
Need to order rear sway bar endlinks
Since I won't buy new wheels and tires (37s) until these are trashed which will take awhile since they are only 4 months old, I decided to paint the stock wheels for now.
DynoMax Evolution Competition P/N: 39516 DOES fit the 2dr also, I had to cut off 2.5" and finagle the rear exhaust hanger bracket, but I love it and sounds great. Also it sounds great with my Banks intake.
Old Mar 22, 2014 | 05:57 AM
mcmahonbj's Avatar
mcmahonbj's Avatar
My tires look so small! :cold:
Old Mar 22, 2014 | 05:59 AM
mcmahonbj's Avatar
Did a few things to the Jeep today. Anyone else have suggestions of things I should do maintenance wise?
-Duralast Idler Pulley
-Duralast Serpentine Belt
-Oil Change Mobil 1 5w-30 Full Synthetic
-Bosch 3422 Oil Filter
-New Drain Bolt w/ Washer
-Autolite Platinum Spark Plugs (gapped .050)
-Removed Exhaust Heat Shield
-Rotated Tires
Anyone know how to stop this corrosion on my battery terminal?
Randoms:
How the old plugs looked, no clue how long they have been in the Jeep.
Is the angle of the front driveshaft bad?
yep anti-seize on the threads and grease on the other end. I didn't put grease in the plug wire end, should I have? Well I didn't think about wires, maybe I should. I just got the Autolites since they were just as good as OEM replacement ones and $1 cheaper. I am at 55,140 right now. Just like keeping up on maintenance and wondering what else to tackle. If someone doesn't pass on something good to buy the extra hundreds will go into my AR15 or towards my E30 325 BMW Coupe build I will be doing soon, once I source a rust-free one.
Old Mar 22, 2014 | 06:00 AM
mcmahonbj's Avatar
Update to my AR15
SOPMOD Stock
EOTech
Troy Flip Ups
SureFire rail mounted pressure switch
Rainier Ambi Charging handle on the way. Still need to order my Timney trigger and the CREE Bulb for the Surefire
3/17/2014
Bought:
-BCM KMR 13" Rail
-Key Mod Hand Stop
-Key Mod Sling Mount
-BCM Mod 2 Grip
-Selling DD AR Lite 12.0 Rail w/ Magpul AFG grip, Universal rail-mounted sling point and DD AR Lite Barrel Nut Wrench $250
