no lift on 35's
Thanks for the info!
On taking it to the shop...they are taking my factory TPM sensors out and putting them in the new wheels and tires and then mounting and blancing them. Sorry, I do not have a tire breakdown machine or balancing machine.
I am, however, installing the lift myself!
Putting the 35's on now saves me having to drive the Jeep all weekend with a lift and factory teeny tiny tires on it until Monday.
i love the no flares look because i want as much tire to be showing as possible but is there any way to cover up those holes and make it look flush/clean?
The best and easiest way to do it would be to paint those areas black. If you are just considering cosmetics and want to be able to put them back on at some point then paint it black. If you want to make the holes disappear well the your fixes are endless really.
hey, pick some of these up, cheap and lifts it up an in" and its an easy install. i did my jeep in 4 hrs by my self a jack and 1 jack stand. that will give you a little bit of space.
h ttp://cgi.ebay.com/ebaymotors/1-0-Jeep-Wrangler-JK-Lift-Kit-Spacer-Budget-Boost-_W0QQcmdZViewItemQQfitsZMakeQ3aJeepQQhashZitem3f03 2752deQQitemZ270635848414QQptZMotorsQ5fCarQ5fTruck Q5fPartsQ5fAccessories
DC do you have any rub with the flat flares (got the same ones) in the rear when at full flex? I have not put 35's on yet, but am going to in the future and want to know if I should get a 2.5" lift to prevent any rubbing.
[/IMG]
[/IMG]
