no lift on 35's
Old Jan 27, 2011 | 03:57 PM
  #41
OpenTrackRacer's Avatar
Duratrac 35" tires. Stock Rubicon suspension, Rough Country 1.25" body lift, Rugged Ridge flat fender flares, trimmed rock rails and pinch seam, front stubby.
I have no rub at full flex, even with the swaybar disconnected.
Old Jan 28, 2011 | 11:34 AM
  #42
gatesy21's Avatar
I just want to be sure, I have a 09 jku sahara, and am going to pull the trigger on 35s with new wheels and flat fenders. I just want to make sure they will fit and not rub in everyday driving. thanks in advance guys
Old Jan 28, 2011 | 11:59 AM
  #43
silvurback's Avatar
You SHOULD be good if you have flat fenders. When I had my stock fenders on with the 35's, they would scrub a little when I hit a bump, but after I pulled them off, I never rubbed on the street. You'll probably need to do a little trimming/bending on the rear, forward pinch seam though. Post pics when you get your stuff installed.
Old Jan 28, 2011 | 12:01 PM
  #44
silvurback's Avatar
Originally Posted by OpenTrackRacer
Looks great bro
Old Jan 28, 2011 | 12:22 PM
  #45
DCJEEP's Avatar
I run that setup right now and you'll be fine (mines a rubi). I'm running 315/70/17's and the wheels have 4.5" backspacing. Only thing you have to do is trim that crappy plastic airdam.
Old Jan 29, 2011 | 01:07 PM
  #46
jakwi's Avatar
Originally Posted by silvurback
mine through a few different stages. all stock on 35's....
35x13.50x15 BFG Krawlers
no fenders...
35x12.50x15 BFG KM2's
What rims are you using? Are they steelies? Looks awesome!
Old Jan 29, 2011 | 07:35 PM
  #47
silvurback's Avatar
Thanks! They were Cragar Soft 8's, 15x8, 4" backspacing and -12mm offset. We had to shave the front calipers a bit to make them fit properly, but it was worth it IMO. I think some people go with 3.75" backspacing and sometimes don't have to grind on the calipers Someone correct me if I'm wrong.
Old Jan 29, 2011 | 07:46 PM
  #48
JocKy's Avatar
Originally Posted by jk noob
i love the no flares look because i want as much tire to be showing as possible but is there any way to cover up those holes and make it look flush/clean?
I'm surprised a company hasn't come up with a cover plate for the no fender look!
Seems like some one like Poison Spyder has the body mold for their fenders.....just dont weld on the fenders! Send them bare....we paint them
HINT HINT
Old Jan 31, 2011 | 07:19 AM
  #49
Everyday driving should be fine but you'll probably find a few rubs off-road. I had to turn my front bumper into a stuby because the tires would rub when articulated and turned (and I had to trim the pinch seam, even with the body lift).
Old Jan 31, 2011 | 08:12 AM
  #50
Seal's Avatar
HINT HINT
I'm sure if you ask nicely the guys at Poison Spyder could make something like that up for you
