The Official " Show me your JK on 15 inch Wheels " thread
Old Mar 18, 2014 | 02:37 PM
  #471
Aztecdiver's Avatar
Ok. I had it backwards then. So, the lower the number the more the wheel is pushed away from the Jeep? Like a 3.75 will stick out farther the a 4". Is this correct?
Old Mar 21, 2014 | 01:17 AM
  #472
johnnymoha's Avatar
@Big Buger
What size and brand wheels are those and did you have to do any grinding or spacers or anything? They look great! I tried black rock 952 15x8 3.75"BS on mine and they wouldn't even sit flush against the hub because of a weird extrusion on the back of the rim that extended beyond the flat part with the holes for the studs. I'm hoping the procomps are different even though they look exactly the same from all the pictures I've seen.
Old Mar 21, 2014 | 01:24 AM
  #473
AaronJK's Avatar
Yup, that's right.
Sent from my SAMSUNG-SGH-I727 using Tapatalk
Old Mar 21, 2014 | 01:51 AM
  #474
aaronstephen's Avatar
Here's my JK on 35/12.5/15
Sent from my iPad using Tapatalk HD
ID:	539246   Click image for larger version
Old Mar 31, 2014 | 04:54 PM
  #475
Aztecdiver's Avatar
I am getting 15's. I already bought tires. Please tell me the pros and cons between going with a 8 vs a 10" rim. I havent seen anyone explain this. Thank you.
Old Mar 31, 2014 | 06:49 PM
  #476
Big Buger's Avatar
Originally Posted by johnnymoha
@Big Buger What size and brand wheels are those and did you have to do any grinding or spacers or anything? They look great! I tried black rock 952 15x8 3.75"BS on mine and they wouldn't even sit flush against the hub because of a weird extrusion on the back of the rim that extended beyond the flat part with the holes for the studs. I'm hoping the procomps are different even though they look exactly the same from all the pictures I've seen.
i can't remember what model they are but they are pro comp wheels 15"x9 with 4.5" back space. No need for wheel spacers or anything. The tires are 35x12.5r15 km2. If you still have the rims with 3.75 back space you should be able to get wheel spacers to get them to fit. But not totally positive about that.
Old Mar 31, 2014 | 07:33 PM
  #477
Aztecdiver's Avatar
Shouldnt a 3.75 backspace give more clearance from the caliper then a 4.5?
Old Mar 31, 2014 | 07:43 PM
  #478
JurassicJeep's Avatar
We've been running 10" wide wheels on our past 3 Jeeps. Main reason is that I wanted the additional width, plus I think the 12.5" wide tires flex better on a 10" wide wheel. I know some say that you'll pop a bead on the wider tire, yet we run ~12PSI and have never (knock on wood) had a blown bead.
I attached a couple of pics of our 15x10 wheels.
ID:	542339   Click image for larger version
ID:	542340   Click image for larger version
Old Mar 31, 2014 | 08:01 PM
  #479
chevyok06's Avatar
Name:	Jeep MC LIFT.jpg
Here is mine on 15s. I love them twice as much when i air down to 12 psi.
Old Mar 31, 2014 | 08:52 PM
  #480
Chattinfarms's Avatar
Here is mine. Procomp rock crawler with fake beadlock. 15x10 3.75 bs.
