The Official " Show me your JK on 15 inch Wheels " thread
Old Mar 31, 2014 | 10:16 PM
  #481
G3N3RAL's Avatar
running 35" BFG KM2 on 15x8 MB wheels I am running this combo on a 2.5" Rubicon express coil lift.
Name:	more phone pics 018.jpg
ID:	542374Click image for larger version
Name:	more phone pics 021.jpg
ID:	542375Click image for larger version
Name:	more phone pics 027.jpg
Old Mar 31, 2014 | 11:14 PM
  #482
shj_jeep's Avatar
Here you go
ID:	542379   Click image for larger version
ID:	542380   Click image for larger version
Old Apr 1, 2014 | 02:13 PM
  #483
Crippler's Avatar
35/12.50/15 MTR/K on 15x8 MB Razors
Old Apr 1, 2014 | 02:40 PM
  #484
Aztecdiver's Avatar
Originally Posted by JurassicJeep
We've been running 10" wide wheels on our past 3 Jeeps. Main reason is that I wanted the additional width, plus I think the 12.5" wide tires flex better on a 10" wide wheel. I know some say that you'll pop a bead on the wider tire, yet we run ~12PSI and have never (knock on wood) had a blown bead.
I attached a couple of pics of our 15x10 wheels.
Those look awesome. What is that wheel and the backspacing? Did you do any modifications or did it fit good from the factory?
Old Apr 1, 2014 | 04:59 PM
  #485
JurassicJeep's Avatar
Thanks!
15x10 Pro Comp's w/ 3.75" BS
I have about 3" of lift from using Rubicon 19/60 springs and a 1" spacer in the front plus 1/2" in rear.
Here are some pics without the lift. It would have wheeled fine with bump stops to keep the tires from tearing things up. The trimming really opened things up!
ID:	542581   Click image for larger version
ID:	542582   Click image for larger version
ID:	542583   Click image for larger version
Old Apr 1, 2014 | 05:13 PM
  #486
jackoskate's Avatar
Old Apr 15, 2014 | 07:40 AM
  #487
xsv's Avatar
xsv
15 inch Helo 791
35x12.5R15 Mickey Thompsons
Name:	jeep with rims.jpg
BB waiting in the garage for some warmer weather.
No grinding needed. Although I couln't use sticky weights on the inside of the rim.
Old Apr 15, 2014 | 09:27 AM
  #488
MAINEGUY's Avatar
2010 Sport, 2.5" BB with 2014 Rubicon 19/59 Springs and Shocks, 35x12.5x15 BFG AT with MB Razors.
ID:	545891   Click image for larger version
ID:	545892   Click image for larger version
ID:	545893   Click image for larger version
ID:	545894   Click image for larger version
Old Apr 15, 2014 | 12:07 PM
  #489
Hogghead's Avatar
How do you like the Rubicon express lift? I was thinking of getting the spring and shock kit.
Originally Posted by G3N3RAL
running 35" BFG KM2 on 15x8 MB wheels I am running this combo on a 2.5" Rubicon express coil lift. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=542374"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=542375"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=542376"/>
Old Apr 22, 2014 | 06:20 AM
  #490
soonerfan85's Avatar
My 15" Dia 8" Wide Level 8 Punch wheels with -19mm offset wearing 33" x 12.5" Duratracs. Brake caliper clearance in front is OK, about that of a piece of Trident gum. Rear is pretty tight, about that of a piece of Wrigley Spearmint gum. May eventually shave a little off the rear calipers if I get inspired one day.
ID:	547553Click image for larger version
