Painting a JK Olive Drab
Old 02-16-2010, 01:26 PM
  #201
Originally Posted by kozz
MY WRANGLER JK RUBICON......
I like that a lot man, If I get a 2010 this summer I'm thinking of something like that if I get black or Jeep green or whatever the dark green is called now
Old 02-16-2010, 01:44 PM
  #202
Lo2aY's Avatar
Welcome to the forum.
make sure to post pics of your JK whenever you get it
Old 02-16-2010, 04:27 PM
  #203
JPSquad's Avatar
That JK turned out great! Do you guys have any other projects in the works?
Old 02-19-2010, 11:09 AM
  #204
Former Vendor
Rugged_Ridge's Avatar
Well... I just found this thread... better late than never. Been running this paint for some years myself... It's not a JK but I kind of like it!
JK's looking great!
Name:	3.4 small.jpg
ID:	37435   Click image for larger version
Name:	Side small.jpg
Old 06-02-2014, 07:08 AM
  #205
Geotechnical's Avatar
Default OD paint steps
Originally Posted by BBirish
Here are some shots of RubiConVict's JK which he decided to have ChevyM14 rattle can olive drab and it came out great. This is a work in progress and is going on day 3 of work, still to be added are military decals and finish up the doors.
Forum members involved:
RubiConVict
ChevyM14
BBirish
JK408
Racer83l
Attachment 21374
Attachment 21376
Attachment 21377
Attachment 21378
Hey, just saw,this thread after searching for OD jeeps. I was looking at the original crappy paint job done from the factory on my 08 wrangler. There are some spots around bolt heads where you can actually see primer. Looks like the paint booth guy was asleep on the job. I was also beginning to notice the various rust spots and under paint rust on the door hinges that are starting to form and p@;/ me off. I just mentioned to the wife I was thinking About painting the jeep OD and she said no problem! God love her.
Anyways, after a quick search I saw this thread, and was wondering if you could elaborate on the steps you did for the paint job.
-did you remove all the plastic (door panel bits, interior trim) seats etc?
-did you use a spray booth? I don't have access to one, but I do have a good sized garage
Did you use a primer?
-did you hand sand everything?
-I Checked the website for the paint, but they don't have any paint listed
Thanks
Old 06-02-2014, 09:06 AM
  #206
ChevyM14's Avatar
Thanks
Wow, old post. anyway,
we did remove almost all the plastic (it was a lot of work but not the seats, the inside was already bead lined)
did not use a spray booth, we did it with cans if you can believe that.
did not use a primer
had sanded everything
as for the paint, it looked great for about a year and then started to fade a good amount, he repined it camo (black, green, tan) for a year or two and then had it painted mat black. the camo looks really cool but will fade at some point (just look at old army trucks)
Old 10-03-2021, 10:20 PM
  #207
josh1998tj's Avatar
Default Color code
Hello, do you guys happen to have the olive drap color code??
Old 10-04-2021, 10:32 AM
  #208
Moodyalaskan's Avatar
In my time in the military I found that there were/are many shades of OD paint from a shade of almost brown to a forest green color.
This web site has the Federal Standard (FS) number for paint. Down toward the bottom is where most of the green OD is listed.
There are some also in other areas just look for green. Also the type of paint will effect the color a small amount, ie. gloss, satin or flat.
Federal Standard 595 Colors (dampney.com)
Quick Reply: Painting a JK Olive Drab
