Pic Req. 1.5" Teraflex leveling kit & stock 32's
Old Feb 7, 2011 | 05:22 PM
JulianK's Avatar
Default Pic Req. 1.5" Teraflex leveling kit & stock 32's
Don't want to change up my stock 32's yet but I'd like to put on the T-flex leveling kit (probably the spring kit). Would like to know what it'll look like and that it won't look stupid.
Thanks in advance!!!
J.
Old Feb 7, 2011 | 07:00 PM
jesse0376's Avatar
ID:	125425 this is mine with tf leveling kit next to my yj with 35s. mine has the spacer kit
Old Feb 7, 2011 | 07:10 PM
matt33's Avatar
Here's my 2010 Rubicon UL with the TF spring kit installed:
Old Feb 8, 2011 | 03:20 AM
JulianK's Avatar
Exactly what I wanted to see.... Thanks all! Hey Matt, is there a difference in the ride between the stock springs and the Teraflex ones??
Old Feb 8, 2011 | 04:11 AM
RedJK2's Avatar
Installed this past weekend! Note that this is not the performance kit.
Before:
After:
Old Feb 8, 2011 | 08:06 AM
Mosssr's Avatar
I hope to have mine on soon. Pics to follow
Old Feb 8, 2011 | 05:01 PM
matt33's Avatar
Not much. The TF springs are a little stiffer, but it's hardly noticeable except under heavy braking and on very twisty roads. I like the slightly firmer ride better. Keep in mind I have a Rubicon which is said to have heavier OEM springs than the other trim levels. The ride change may be more noticeable in an X.
Old Feb 8, 2011 | 05:06 PM
nickel_13's Avatar
[IMG][/IMG]
Old Feb 8, 2011 | 05:12 PM
boots's Avatar
Hey guy's, I think the leveling kit really makes a big differance. It also screams 33's.
35's might be a bit tight.
Old Feb 8, 2011 | 05:40 PM
jesse0376's Avatar
not sure how much the spring kit is but i think the spacer kit for 150 bucks is the way to go. if your gunna spend money on springs get more lift. the spacer kit is just fine. and 35s would fit if you went with flat fenders or fender trim and front stubby.
