Project-JK Gets Off Road Evolution EVO-flex - Part 2: Rear EVO Lever
JK-Forum Founder
WOW! That is absolutely impressive. Your JK is wicked, WOL.
Curious about that exhaust though. I understand why you ended the system where you did, but it seems like a bad idea to exhaust it under the JK. Why not route the pipe out to the side a bit, in front of the wheel well or something? I can't imagine that's good for breathing while driving, especially if you've got the drain plugs pulled.
yup, that's a 2nd battery but you could easily fit an air tank up there as well
Eternal ***erator
JK-Forum Founder
unfortuantely, we ramped it just as a final check before heading out to niagara rim. i will go back and document it and let you all know the results.
once again, this was accomplished with just a good set of adjustalbe short arms. while i am running teraflex arms now, i have run full traction as well and can tell you that both will do the job well. of course, if you can afford to install this with a good 4-link long arm kit, your flex will be stupid crazy
here are a few shots of off road evolution's jk which has the EVO coilovers up front, EVO lever in the rear, full traction long arm kit, 40" toyo's and on a 30° ramp....
crazy thing is, their JK would have easily gone up higher on the ramp and was only stopped because of the wall it was attached to
