Project-JK Gets Off Road Evolution EVO-flex - Part 2: Rear EVO Lever
Old Sep 2, 2008 | 06:10 AM
HappyCurmudgeon's Avatar
Eternal ***erator
damn that looks sweet!
Old Sep 2, 2008 | 06:16 AM
Gokracer1's Avatar
Great Write up! That is crazy stuff...
Old Sep 2, 2008 | 06:41 AM
SGT.'s Avatar
Great stuff and even better to see it in person!!!!
Old Sep 2, 2008 | 07:00 AM
robin's Avatar
wow awesome.
Old Sep 2, 2008 | 08:55 AM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by riverzendz
WOW! That is absolutely impressive. Your JK is wicked, WOL.
Curious about that exhaust though. I understand why you ended the system where you did, but it seems like a bad idea to exhaust it under the JK. Why not route the pipe out to the side a bit, in front of the wheel well or something? I can't imagine that's good for breathing while driving, especially if you've got the drain plugs pulled.
honestly, i haven't noticed this being a problem and haven't had any issues with fumes - or, at least, none that i could tell. but, i'm sure you could have your exhaust routed just about anyway that you want so long as it stays out of the way of the EVO Lever.
Originally Posted by Major Ho
Just curious, with a mod like the Woods Evap Canister relocation would they be compatible with each other since the evap can sits above the rear axle area?
yes, so far as I can tell, this shouldn't be a problem.
Originally Posted by bahadden
whats that red battery looking thing up under the evo lever system?
looks great, got used parts you need to get ride of
yup, that's a 2nd battery but you could easily fit an air tank up there as well
Old Sep 2, 2008 | 09:17 AM
Eternal ***erator
[snip]
uber-secret Project-JK hybrid experiment.
Old Sep 2, 2008 | 11:23 AM
TeraFlex's Avatar
Sponsoring Manufacturer
NICE!!! Love the flex!!
Old Sep 2, 2008 | 11:45 AM
snippy's Avatar
I see you had the ramp out, what was your RTI score?
Old Sep 2, 2008 | 11:50 AM
bly109's Avatar
That Evo-lever is badass Im gonna have add that and front coil-overs to my wish list.
Old Sep 2, 2008 | 12:02 PM
wayoflife's Avatar
JK-Forum Founder
unfortuantely, we ramped it just as a final check before heading out to niagara rim. i will go back and document it and let you all know the results.
once again, this was accomplished with just a good set of adjustalbe short arms. while i am running teraflex arms now, i have run full traction as well and can tell you that both will do the job well. of course, if you can afford to install this with a good 4-link long arm kit, your flex will be stupid crazy
here are a few shots of off road evolution's jk which has the EVO coilovers up front, EVO lever in the rear, full traction long arm kit, 40" toyo's and on a 30° ramp....
crazy thing is, their JK would have easily gone up higher on the ramp and was only stopped because of the wall it was attached to
