View Poll Results: Should i paint the Xenon flares?
Painted black body matched
65
51.18%
leave them plastic
62
48.82%
Voters: 127. You may not vote on this poll
Project: JK (re)build Final touches
Old Jul 12, 2009 | 07:21 AM
  #171
6DoF's Avatar
that was the alignment stuff, but i found the trouble code page.
i think its the fact that that pitman it offset that is messin with me ...
Old Jul 12, 2009 | 07:31 AM
  #172
09rubicon's Avatar
It is quite possible it slipped a few splines in the rollover. I would still try adjusting the draglink first before really screwing with the pitman/steering box. Sadly if the pitman did jump a few splines then you are probably stuck getting a new steering box as the sector shoft itself is not an idividually replacable unit.
Old Jul 12, 2009 | 07:51 AM
  #173
6DoF's Avatar
that's what i was scared of, but wouldn't be hard to fix. is that something that has happened to ppl? i've heard of the sector shaft breaking, but never loosing splines ...
Old Jul 12, 2009 | 07:53 AM
  #174
09rubicon's Avatar
I haven't actually heard of it happening in the JK, which is why i would stick with adjusting the draglink first. I have seen it happen in some older vehicles (mostly fullsize) and I think I have read of one case where a JK sector shaft actually broke. In general the JK steering box is fairly stout, the most common issues are internal to it, not physical breakage of the sector shaft or seperating from the frame.
Old Jul 12, 2009 | 07:55 AM
  #175
6DoF's Avatar
ok, i was just reading somewhere else that if all the lights are on and the airbag light that something else might be wong ... but they never said what. my airbag light is also on.
Old Jul 12, 2009 | 08:11 AM
  #176
6DoF's Avatar
Originally Posted by OlegFl
Did you check what codes the JK is spitting at you?..... I would check and write down all the code. Than bu an AEV procal (cheapest).... with the AEV, reset all the codes.... than see what codes show upp after a short drive.... I'm sure you must have fixed half the codes by now ... when done... re-sell the AEV and you'll probably end upp losing less than $30 on it
cheapest doesn't always mean the best ... what module has the most option and is the most usable?
Old Jul 12, 2009 | 08:18 AM
  #177
09rubicon's Avatar
Not the right question. The right question is what do you want it to do.
Superchips Programmer = Power wise its the biggest bang for the buck and alot of people happy with it. Alot of its supposed options are not enabled though.
Hypertech = Good programmer, all functions work, not as much power increase for the price paid. Still alot of happy customers though.
AEV Procal = No power programming or tunning. Can reset many functions and change others. Fastest programmer out there, easiest to use, and cheapest. If your not looking to "add power" this is the way to go.
Old Jul 12, 2009 | 08:28 AM
  #178
6DoF's Avatar
air bag light is on ... esp/bas light is on ... traction/stabilty light is on.
the traction stability light will go off if i push the esp off button 2x
pulled the codes ... no cods. just 6 dashes and -done-
Old Jul 12, 2009 | 08:31 AM
  #179
6DoF's Avatar
yeah, the more options the better ... and more power would be nice too. is it better to get the superchips and procal for the most power and most option, or will the hypertech do it all with just not quite the power?
Old Jul 12, 2009 | 09:03 AM
  #180
09rubicon's Avatar
I have the Hypertech and am happy with it. Its not like suddenly having 2 more cylinders, just a little easier to get the 35s moving and a little less need to downshift on the hills. Its noticable if you know where to look. I have heard great things about supperchips too, not knocking them.
I also use the Procal (yes the "stack" fine) to adjust for tires, gears, DRL, codes, etc. as it is quick and fast and portable (i keep it and the card that comes with it in the glovebox).
