View Poll Results: Should i paint the Xenon flares?
Painted black body matched
65
51.18%
leave them plastic
62
48.82%
Voters: 127. You may not vote on this poll
Project: JK (re)build Final touches
Old Jul 27, 2009 | 03:39 AM
  #271
6DoF's Avatar
Originally Posted by mscedro2
I found some info that may or may not help you...
- Verify the connector pins are fully seated properly in the OBDII connector housing.
- Using a volt meter or continuity tester, verify pin 4 is grounded.
- Using a volt meter or continuity tester, verify pin 16 has power when key is turned to IGN position. If not, check fuses.
J1850 Pin Descriptions:
2) J1850 Bus+
4) Chassis Ground
5) Signal Ground
6) CAN High
10) J1850 Bus
14) CAN Low
16) Battery power
thanx man ... are you talkin about the connector on the Superchips or on the jeep?
and what fuse runs that?? i can't find that info anywhere.
if anyone has the manual with the wiring i'd love to know what color wires and connectors to trace too ...
Old Jul 27, 2009 | 05:15 AM
  #272
JonnyCub's Avatar
Should have chopped it and built a rock buggy.
Old Jul 27, 2009 | 06:13 AM
  #273
6DoF's Avatar
already have a YJ far enough along those lines they won't let it on the roads ... buildin this cuz i need something to drive.
Old Jul 27, 2009 | 07:52 AM
  #274
luisgus's Avatar
You are the man, I saw the first steps of the build and now this. U rock man, sick jeep.
Old Jul 27, 2009 | 08:10 AM
  #275
mscedro2's Avatar
The connector on the jeep. ^x2 on the wiring schematics to find the fuse...please chime in .
Old Jul 27, 2009 | 08:11 AM
  #276
brandonbooth's Avatar
You know when I first saw this I thought this would be a long project... you are pumping this thing out seems like you are going to be done with it in now time... good job it looks great so far!
Old Jul 27, 2009 | 08:26 AM
  #277
6DoF's Avatar
thanx guys, keep the comments coming cuz they are keepin me going!!
i was actually hoping to have it done by now ... and the paint just got streached out a little more. i've broke down to doing all the paint myself in the driveway ... and just wet-sanding the dust out before and after clear ... i've already stretched myself thin enough with stupid things i gota save the $4-600 labor cost.
hopefully i hear back from Smittybuilt about the bumper and 4WD gets my wheels in soon. the glass is next day when i get the frame painted ... and i hope to figure out the OBD II plug here ASAP.
Old Jul 27, 2009 | 09:16 AM
  #278
RN M OVR's Avatar
This is blowing me away. When I saw the parts come I was like Then when I saw your JK sitting on the KM2's I splooged at work. Now I have to find a way to catwalk out of here. What a build. Truly impressive!
Old Jul 27, 2009 | 09:43 AM
  #279
6DoF's Avatar
Old Jul 27, 2009 | 01:13 PM
  #280
6DoF's Avatar
you ever have one of those "WOOHOO!!! ... lame" moments? i just had one.
called Smittybuilt, great service by the way, to find out that i have and XRC rear bumper and an SRC swingout. so WOOHOO i don't have to mod a swing out and can get all the right parts ... but lame that Chad sold me the wrong parts!!
