View Poll Results: Should i paint the Xenon flares?
Painted black body matched
65
51.18%
leave them plastic
62
48.82%
Voters: 127. You may not vote on this poll
Project: JK (re)build Final touches
Old Jul 28, 2009 | 08:20 AM
  #291
6DoF's Avatar
Originally Posted by mscedro2
Sleep is overrated
normaly when it comes to workin on the jeep ... i would agree. but that 6:15am alarm and trying to be awake enough at work to even pretend i'm workin gets a little hard.
Old Jul 28, 2009 | 08:51 AM
  #292
6DoF's Avatar
would also like to put in a new shout-out for:
LIQUID IRON INDUSTRIES and the founder Tim.
liquidironindustries. com
tim@liquidironindustries. com
i know Tim and his work, and have spent time on the trail with him. i've worked out a deal to donate my JK to the cause end of october, early november. a LOT of new JK parts will be coming on the market as a result from the deal!
one thought has been a FULL CAGE WELD-IN KIT. so we want to know what/if any interest is out there and what options you want to see!!! give me your idea's and i'll pass it all on! also let me know if there is a void that needs filled for parts you need!
stay tuned for this one ya'll, it's guna be good!
edit: sorry about that!!
he has full intentions of gaining the sponsor status once an appropriate product line is more established
Old Jul 28, 2009 | 04:27 PM
  #293
6DoF's Avatar
ok ... a couple of things
first off i jumpered power to pin 16 of the OBD II port and the programmer worked great! i'll have to just make a new 12v lead.
however there are other issues. i cleared the codes and chit came right back. the programmer picked up 2 codes:
U0154: LOST COMMUNICATION WITH OCCUPANT CLASSIFICATION MODULE
U1147: it's not even in my PDF but the thing said something about detected another computer or something.
any idea's???
Old Jul 28, 2009 | 06:31 PM
  #294
JeepDawg's Avatar
Default U1147
U1147 - "Loss of serial communications for class 2 devices"
I also found this description - U1147 - "Invalid or Missing Data for Vehicle Security"
I don't know what it means, but most Uxxxx codes all have this exact same verbiage. The "U" stands for the class 2 network. The U1145 is "loss of NAV communications" and U1146 is "loss of OnStar communications". So, since 1147 is the next number in line, my guess would be is that may be related to the radio head unit - - malfunctioning, disconnected, etc. Do you have the RER or REN, is it installed, and does it work?
U0154 - "Lost Communication With Restraints Occupant Sensing Control Module"
This one sounds like the seat belt sensor to me. Don't we have a front seat passenger sensor on the JKs? Is everything hooked up under the front seats? Maybe water damage to some connectors?
Just guessing here.....These sound annoying, but not hard to fix (compared to what you've been through)!
Old Jul 29, 2009 | 03:17 AM
  #295
6DoF's Avatar
everything under the seats looked good ... those along with the power wire to the OBD II port going out, makes me think glass got to a wire under the dash or something. so tonight im going to pull the whole fakkin dash off and trace that SOB wire till it stops having connection. my hope is that maybe the 12v for that is the suply for some occupant sensor as well.
onstar would be a GM code ... and the radio works fine, its just the basic MP3/cd deck. no clue what RER or REN are ...
and this is what REALLY pisses me off ... b/c i have to pass PA inspection, i can NOT have the airbag light on. my jeep is 100% functional and safe to drive, and i bet the airbags would still go off! but as long as that light is on, i will never be alowed on the road. YAY for more computers!
Old Jul 29, 2009 | 04:29 AM
  #296
JeepDawg's Avatar
Originally Posted by 6DoF
.....onstar would be a GM code ... and the radio works fine, its just the basic MP3/cd deck. no clue what RER or REN are ...
From the best I can tell, the U codes are not vehicle specific, but are class 2 network generic....hence the Onstar code in the list. RER and REN are 2 of the NAV radio models that we have on our Jeeps. I was guessing you might have one of them. You will see the model name on the lower right of the radio head unit.
I think you are right about a severed wire somewhere.....
Did the "vehicle security" explanation give you any ideas?
Old Jul 29, 2009 | 05:39 AM
  #297
6DoF's Avatar
i'm currently un-aware of any vehicle security in my jeep ... i was handed a single key when i bought it, no fab, power nothin. so unless my music only radio has its own army, or i'm just in the dark on this, i got nothin.
it has to be a broken wire somewhere ... i was unable to find ANY wire under the hood around the fuse block that was connected to pin 16. as well as fuse M22 (10A) isn't connected to either the batt or gnd. now i havn't check that with power on to see if it is suplied thru a relay yet ... but will tonight. so unless there is another fuse block i don't know about, that dash is comin out.
does anyone on this site have carfax and wana run my VIN?? i know there is stuff on there but i havn't been able to see it.
Old Jul 29, 2009 | 05:45 AM
  #298
6DoF's Avatar
hey hey, that diagram also shows more power being taken off the back side of that fues then just OBD II pin 16 ... now if only it said what that was ...
Old Jul 29, 2009 | 08:42 AM
  #299
Spytec128's Avatar
Veteran: Navy
It looks like it goes to the powertrain module.
Old Jul 29, 2009 | 08:58 AM
  #300
6DoF's Avatar
well, now i'm really confused ...
minor update, i'll get pics later. found a pair of sunglasses way up inside the dash above and to the right of the glove box i hope to find a lot more in there as it all comes apart tonight ... maybe even the manual!
also started to call around to see if anyone might have 2 of my wheels ... dude finaly called his suplyer who said those were new and on a national back order till the 3rd week of aug. at least now i have a time-frame to wait for.
then still end of september for the tire swingout. i called quadratec and 2 different guys have sounded SUPER confused when i asked to get just the swingout ... said it wasn't possible. need to befriend some smittybuilt rep to call the q-tec warehouse and see if any are lyin around ...
oh well, i'll have to rig some random 3rd brake light till that comes in, and won't have this thing done for vacation
