Rigid Duallys Installed
Old Jul 21, 2011 | 08:22 AM
Hellbound13's Avatar
Default Rigid Duallys Installed
Finally got my Rigid Duallys and installed them right away. These replaced my WARN wireless lights on my front bumper and I must say they are MUCH brighter.
2600 lumens each, and the fit and finish is top notch. Really high quality wiring, housings and brackets are used. The lenses are impact resistant.
Wiring was straight forward and simple.
Here are some pics..
ID:	184199   Click image for larger version
ID:	184200   Click image for larger version
Old Jul 21, 2011 | 09:21 AM
woodyvw9's Avatar
Veteran: Coast Guard
Looks good!
Old Jul 21, 2011 | 08:30 PM
deeker's Avatar
I put some on the windshield brackets that Gus from ORW was offering as a combo package.
Here's the result I got.
Old Jul 21, 2011 | 08:35 PM
briaros6's Avatar
Hey anyway you can take a picture of the antenna side?
Old Jul 21, 2011 | 08:55 PM
Stonewhite JK's Avatar
Hows the hood glare with the windshield mounted ones?
Old Jul 28, 2011 | 07:24 AM
deeker's Avatar
I will try to get a picture of the antenna side. Basically, a little piece of flat stock steel with a rubber grommet fits on the light bracket and slides down the antenna, holding it firm and from whacking the side of the light. Simple but effective.
You can see it in this photo, at least enough to give you an idea as to what the little piece does...
Glare off the hood is not too bad at all. The lights are pretty low so they don't spill over the hood too much. They do light up the fender and side of the hood but my driving position is far enough back that I can barely see it. If I sat up close to the wheel it might be more of a concern. I don't have a problem with the pass. side at all.
Hope this photo helps.
Old Jul 28, 2011 | 12:55 PM
highoctane's Avatar
Sweet. I'm getting a set of these for free from Poison Spyder for buying a new Rock Brawler rear bumper/tire carrier as part of their July special. Can't wait to install them.
Old Jul 28, 2011 | 04:37 PM
Harve10's Avatar
I like that a lot, well done.
Old Jul 28, 2011 | 04:52 PM
Ryan0260's Avatar
Looks really good
