Show and Tell: Rock Krawler Style
Attachment 607941
1.5" springs, bilstein shocks and front sway bar discos. Overall a big improvement over stock.
Getting ready to install upper and lower control arms on the rear in the morning along with new spring perches to compensate for moving the axle back. Have the 3.5" lift. Does anyone know what pinion angle Rock Krawler calls for? By the way, this is a 4 door.
The uppers can be easily tightened on the jeep. Hold pinion where desired and adjust uppers out to fit the mounts. Recheck pinion without Jack. When happy, center joints and use something like this to wedge inbetween joint and mount to hold orientation. Make sure the bend is inward also.
