Show and Tell: Rock Krawler Style
Old Apr 26, 2015 | 01:08 PM
  #551
kjeeper10's Avatar
Vet Army
Originally Posted by castlerockjeep
Just picked up a used max flex kit for my '14 unlimited! Any tips for the install?
I posted a link in your thread. As mentioned tightening the jam nuts is a PIA.
I would get a hold of a 1 1/2 crowsfoot attachment. I found it to work the best.
RK has The front lowers at 23 1/8,
rear lowers 2 door 19 5/8 (stock = 19 3/4 ) 4 door 20 1/8"
I would set them to 19 3/4 on either and be done.
Old Apr 26, 2015 | 03:30 PM
  #552
d. gage's Avatar
Originally Posted by Stubicon
I've got the same setup and it's great. Just needs a bigger tire.
Attachment 608048
Great looking setup! Is there anything else needed to run these springs? This is something I would like to do with my jku.
Old Apr 26, 2015 | 03:44 PM
  #553
2012-JKU-Brad's Avatar
I run the same set up. All I have are the recommended bilstein shock, brake line drop brackets and rk sway bar discos. I will be adding 1" bumpstops soon. At the bare minimum you can run just the springs, shocks and drop brackets.
Old Apr 26, 2015 | 04:16 PM
  #554
mikeJKUR's Avatar
Very happy with the Rock Krawler 1.5 lift.
http://youtu.be/7Mdyg-n5gDI
Old May 25, 2015 | 07:46 AM
  #555
ronin2120's Avatar
Vet Army
Installed Rock Krawlers front and rear coilovers Click image for larger version
Old May 25, 2015 | 09:16 AM
  #556
Nuclear Cowboy's Avatar
RK 2.5 stock mod and Bilstein 5100's with 35's and flat fenders. So far I'm real happy with it. I'm going to order some front Teraflex sport LCA's soon. The fender liners have been installed since this picture was taken.
Old May 31, 2015 | 08:16 AM
  #557
TJinaJKU's Avatar
awesome thread....I love the pics and info about rock krawler. Those running 3.5" lifted 4drs, is the front driveshaft a "need" or ok to stay stock and upgrade a year or so down the road? Basically I'm trying to make sure I don't cause the domino effect immediately by going 3.5 over 2.5. I'd rather get in on 3.5 flex system, then go to other things and come back to drive shaft and upgrading the suspension further after everything else was addressed
Old May 31, 2015 | 08:47 AM
  #558
jonnyringo893's Avatar
Just put my 3.5 on yesterday. Loving it. Front driveshaft is next on the agenda just to play it safe.
Old May 31, 2015 | 08:56 AM
  #559
ronin2120's Avatar
Vet Army
ID:	612995 Finally flexing out the coilovers. Click image for larger version
Old May 31, 2015 | 05:24 PM
  #560
12JKjeep's Avatar
I ran with the stock drive shaft for 3 months and it was fine. Depends on how often and how hard you wheel your jeep. It should be fine for a while.
