TeraFlex Tech Rear Trackbar Bracket Installation Video
Sponsoring Manufacturer
Great video!
First off I'd like to apologize. I really don't know a lot about suspensions and am probably about to ask a very stupid question but....... Is this bracket only for a a given lift? For example I have the TeraFlex 2.5" Budget Boost. Would this bracket work for this application or is it made for a more aggressive kit such at a 3" or higher? Again i'm sorry if this is a self explanatory question.
Great video!
#1954776 $102.99
It's funny you mention not to put your hand near the arm of the track bar nut or it will hurt you. Guess what I did this past weekend?
Also, what is that bottom hole above the existing track bar hole and the new one?
Nice. That will be very helpful for those with this bkt.
Question - I am about to install the Teraflex 2.5" coil lift on a 2 door. It came with the old style TB bracket (chassis side as oppose to the new axle side one) Is there a big advantage strengthwise to the new bkt.?
I want it to be as strong as possible, and am willing to buy the new bracket if it is really worth it. But, like I said I already have the old style one, so...
Any info. is REALLY appreciated.
Question - is it OK to leave the rear trackbar alone at first? I only ask, because I will be installing the kit this Saturday, and if I order this newer/better rear trackbar bracket, I won't have it in time. Is it safe to ride around with it stock until I got the new bracket? (say 1-2 weeks before I could actually install it)??
Or, is the STRONGEST way to leave the factory mounts alone, and order a Teraflex rear trackbar? I know it is not as cost effective, but would a whole new trackbar (and leave the factory mounts alone) be slightly better so to speak? ( I am installing a TF front TB, as well as TF lca's. So as you can tell, I want it to be dialed in, and strong )
Thanks in advance
