TF 2.5 hardcore offroad pics
Old Jan 26, 2008 | 09:46 AM
  #51
Originally Posted by theosdad
Anyone on this thread with a 2008 unlimited x that has done the teraflex bb with stock 255/75/17's to know if they had rubbing. I am trying to avoid spacers.
I am considering the TF 2.5 BB myself on the 08 stock X (32 inch tires) and I want to know as well.
Old Jan 26, 2008 | 11:17 AM
  #52
flrubicon's Avatar
I am currently running that exact setup. 2008 x unlimited, 2.5 teraflex bb, with extra 3/4" spacers in the front. Stock 255/75/17 with no rubbing whatsoever. I installed the lift last weekend and so far everything is great. This is only temporary though, as my 315/75/16's should be coming in this week.
Old Jan 28, 2008 | 06:37 PM
  #53
Have you maxed out the flex or was this during the course of normal driving?
Old Jan 28, 2008 | 07:36 PM
  #54
atomicmecha's Avatar
i've got an 07, so can't help you folks with the 08, but i did having rubbing on the rear links before i moved both to the inside of the swaybar till i get my 2" spacers.
I got my JK to almost full flex over the weekend:
Old Jan 28, 2008 | 08:06 PM
  #55
xrevx's Avatar
Default 07 with 2.5 and 35's
2.5 and 35's
Old Jan 29, 2008 | 05:57 AM
  #56
Originally Posted by RuBob
Teraflex posts here quite a bit, you'd think they'd like to give us an answer on this.
after wheeling my jk over the weekend really hard for the first time since i put the lift on, i checked the brake line brackets because of reading this, and nothing. Besides all the mud on them, no marks. i checked the clearance and it seems my rear swaybar is missing them by mm...
Old Jan 29, 2008 | 09:17 AM
  #57
TeraFlex's Avatar
Sponsoring Manufacturer
Dr.Dirty- it looks like the problem is that your swaybar links are installed on the outside and not on the inside. With them mounted outside the swaybar will slide back and forth more and cause the rubbing issues that you have. Sorry about the delay in response.
Old Feb 11, 2008 | 09:25 PM
  #58
JulietKilo's Avatar
Originally Posted by xrevx
2.5 and 35's
NICE....
Old Feb 11, 2008 | 09:49 PM
  #59
glwood6's Avatar
Ran the 2.5 BB for a couple of days waiting for the Spidertrax spacers. The swaybar links were only 1/4" away from the inside edge of the wheel. They were mounted on the outside of the swaybar ends. I was fine in a straight line, but going over some bumps I could hear them rub. Turned out they were slightly nicking the wheel balance weights sometimes. I was lucky none of those came off. I did not drive it anymore until I got the spacers.
Mounting the swaybar links on the inside will also alleviate slight rubbing that I was experiencing.
Old Feb 12, 2008 | 07:33 PM
  #60
bOLsAK=3's Avatar
