Old Apr 25, 2011 | 11:47 AM
  #12831
D1EHARD's Avatar
Originally Posted by trmason
Nice looking rig... are those the Jeep center caps?
Thanks! Yes, they are the stock center caps painted dark charcoal gray. Fit great over pro comp steelies.
Old Apr 25, 2011 | 11:48 AM
  #12832
isshinryu28's Avatar
Wht size tire u got on stock carrier? Any problems if 35
Old Apr 25, 2011 | 11:58 AM
  #12833
Burtonripper's Avatar
Had a 33" tire. It fits but rattles the heck out of the tailgate. Too much weight. I even purchased an oversized tire carrier from best top but that still rattled with oversized tire bumpers. The only solution was Xrc tire carrier bumper.
Old Apr 25, 2011 | 12:00 PM
  #12834
JKSTI&R1's Avatar
Originally Posted by finnd1
And you won't tell her about the new lift, will you? Convince her she is shrinking. Replace all her pants with ones that are one in longer.
Old Apr 25, 2011 | 12:05 PM
  #12835
trmason's Avatar
Covered it in snow on Saturday, put a little mud on it Sunday, and today - hosed it off, removed decals, and bobbed it.
ID:	153808Click image for larger version
ID:	153809Click image for larger version
Old Apr 25, 2011 | 12:17 PM
  #12836
finnd1's Avatar
did I mention you should put 3" lifts in your shoes? And once she is convinced she is shrinking and goes to the chiropractor, remove you shoes and jeep lifts and put all her old pants back. Repeat as needed.
Old Apr 25, 2011 | 12:44 PM
  #12837
Yamaha90's Avatar
Today i dropped the Jeep off at the dealership again and said a prayer.
Old Apr 25, 2011 | 12:49 PM
  #12838
Cdyspeed's Avatar
Made my own quick disco went to lowes and picked up a few items works perfect and was real easy and cheap to
ID:	153822   Click image for larger version
Old Apr 25, 2011 | 12:56 PM
  #12839
Yamaha90's Avatar
I have done this. What you find out later it that these pins will rattle and bend after using them when they aren't tight, and There is a little bit of play in the sway bar so your Jeep will lean to the passenger side when no one is in it because of the gas tank. But if you plan on going wheeling the next day or so, these will work fine to keep you from laying in the dirt disconnecting and reconnecting.
The standard pins don't fit the metric sizes all that great.
Old Apr 25, 2011 | 12:59 PM
  #12840
TX_Dave's Avatar
Installed a Teraflex 2.5" lift.Click image for larger version
