Old Apr 10, 2013 | 06:25 AM
  #30881
REDJEEPJK's Avatar
Originally Posted by CollegeCop
Cost you a pretty penny didn't it? haha
Yaaaaa it did but what I don't get is I see jeep jks with 2 50 inch led bars??!!?!!!
Old Apr 10, 2013 | 07:04 AM
  #30882
macmmc's Avatar
Originally Posted by GeckoTY
That's nice! how did you make it?
Cut a piece of 3/4" exterior plywood to fit. Covered it with the appropriate color exterior colored carpet and bolted it to the tube using eye bolts. That will give me tie down locations if I want to use it for carrying things.
ID:	445058Click image for larger version
ID:	445059Click image for larger version
Old Apr 10, 2013 | 07:24 AM
  #30883
Bubblegoose1's Avatar
Originally Posted by DoinwkJK
What's different? I'm thinking of installing a chip.
Don't waste your money on a chip or throttle body spacer.
Tuner is the only way to do it right.
Old Apr 10, 2013 | 11:35 AM
  #30884
GreenJK07's Avatar
X2. A tuner is way more complete, adjustable parameters and you will not have to waste the money on a chip when you buy a tuner down the road.
Old Apr 10, 2013 | 12:49 PM
  #30885
BlackRockBurner's Avatar
Cobra 29 LX; Arizona Rocky Road mount; Firestik M2 mount. Drilling holes and cutting internal tub structure had me concerned, but after the first hole it was all good.
SWR is 1.2 across all channels.
Old Apr 10, 2013 | 01:15 PM
  #30886
JKMARINE's Avatar
Making a portable, high output onboard air system. 2 air compressors, 1 2.5 GA tank, and 1 2 GA tank housed inside a steel trailer tongue box. Coated with bed liner.
ID:	445196   Click image for larger version
Old Apr 10, 2013 | 01:20 PM
  #30887
011Crmn's Avatar
Home made cargo liner
ID:	445200   Click image for larger version
Old Apr 10, 2013 | 02:54 PM
  #30888
TimzToy's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=445165"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=445166"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=445167"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=445168"/>
What kind if bracket is that you mounted your
CB on? I used a (black) shelf bracket, zip tied the Power wires and coax inside it.
Old Apr 10, 2013 | 03:07 PM
  #30889
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=445222"/>
That is a Arizona Rocky Road overhead CB mount. I was thinking of making my own, but decided to just buy one. They also give you enough wire with a 30amp blade fuse to go from the battery to the top of the passenger side windshield. I placed the power and coax outside of the mount just in case I have to troubleshoot.
Also notched the bottom of the Firestik M2 mount similar to the drilled mirror mod incase water finds its way inside.
Old Apr 10, 2013 | 03:40 PM
  #30890
1978cj7jk2012's Avatar
Lights......and bottom tint strip
ID:	445268   Click image for larger version
ID:	445269   Click image for larger version
