Old Oct 26, 2013 | 11:18 AM
  #36061
lobster86's Avatar
Originally Posted by ChesterJFK
Got my synergy drag link flip and JKS trackbar today so I installed this afternoon.. I'm running teraflex 4" coils and teraflex tuned fox shocks (4-6") The trackbar is huge! And a lot heavier than that stock toothpick! I love the adjuster, huge jam nut, and easy to adjust. Same with the drag link, don't have to remove to adjust your steering wheel once you get it all set up. What a huge improvement this made. Jeep has less body roll, tighter steering, and my trackbar is now tight! Ordering the synergy tie rod next! <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=508069"/>
I just did this tie rod and the track bar on mine, huge improvement! I've already tested it out and it holds up! Set the whole jeep on it a couple times and no problems. No more bump steer either
Old Oct 26, 2013 | 11:59 AM
  #36062
D_engel's Avatar
raised the rear lower shock brackets 2", chopped the LCA mounts, and ditched the rear sway bar
Old Oct 26, 2013 | 12:24 PM
  #36063
ChesterJFK's Avatar
Yeah my buddy had his synergy tie rod bend up about 4", make contact with his dual SS bracket (black paint rubbed off onto tie rod) and go back down to level. He was amazed and so was I. And that's why I'm ordering that next. Synergy all the way.
Old Oct 26, 2013 | 01:46 PM
  #36064
GreenJK07's Avatar
Originally Posted by D_engel
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=508191"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=508192"/> raised the rear lower shock brackets 2", chopped the LCA mounts, and ditched the rear sway bar
Is that the EVO rockstar kit?
Old Oct 26, 2013 | 09:04 PM
  #36065
JAM85's Avatar
Looks like it. How does it ride without the rear sway bar? These are on my short list.
Old Oct 26, 2013 | 09:08 PM
  #36066
nvglockster's Avatar
Christened it last night. Sorry, forgot to take pics.
Old Oct 26, 2013 | 09:41 PM
  #36067
TreyJK's Avatar
How did you raise the shock brackets and how long did it take? Probably a dumb question but I'm still learning
Old Oct 26, 2013 | 09:53 PM
  #36068
karls's Avatar
Nope, he re-used the stock brackets after cutting them off.
Cut the old ones off, clean them up, weld them back on a little bit higher. The time to do the job will depend on the tools you've got available and how neat you are with your work. It could take as little as an hour or so but certainly more if you've got a small cut-off wheel instead of a plasma cutter.
Sent from my DROID4 using Tapatalk
Old Oct 27, 2013 | 12:14 AM
  #36069
D_engel's Avatar
Nope. Just cut the stock brackets off and welded them on 2" further up. Using just a cut off wheel and my MIG, it took about an hour per side. Its a real pain cutting off the stock brackets.
I don't notice any difference at all without the sway bar. Its so soft that you can keep it or lose it and it will still perform about the same.
Old Oct 27, 2013 | 05:59 AM
  #36070
horrocks007's Avatar
Got a new steering stabilizer.
Got this to hopefully help with bump steer on rough roads at high speeds.
Yes there is a difference in smoothness, but time will tell how effective it is at high speeds.
