Old Oct 27, 2013 | 06:04 AM
  #36071
BRUT4CE's Avatar
Former Member
Originally Posted by D_engel
Attachment 508191
Attachment 508192
raised the rear lower shock brackets 2", chopped the LCA mounts, and ditched the rear sway bar
Very nice that's one of the things I do to mine front and rear....
Be sure if your not running Metalcloak or synergy progressive springs to use spring retainers. If you have 11.6"+ travel shock,s they will try and unseat.
Very nice job, looks good weld a slider on the bottom and call it a day rock ready....
Old Oct 27, 2013 | 06:55 AM
  #36072
Jekyll2000's Avatar
Level 8 ZXs with 315/75/16 Fierce Attitudes.
Old Oct 27, 2013 | 09:15 AM
  #36073
ItsMeKO3's Avatar
Rugged Ridge grille insert, and Plasti Dipped my grille.
Old Oct 27, 2013 | 09:50 AM
  #36074
TreyJK's Avatar
To anyone who knows, why do the stock shock brackets come from the factory so low? If it isn't very difficult to move them up then why don't the engineers design them with the brackets up higher?
Old Oct 27, 2013 | 11:26 AM
  #36075
ChesterJFK's Avatar
They can't come This way because the shock will bottom out before you hit the bumpstops. You have to run a lift kit to do this as well as appropriate bumpstop lengths.
Old Oct 27, 2013 | 11:30 AM
  #36076
GreenJK07's Avatar
Exactly. The shock mounts from the factory are set according to the factory suspension characteristics and ride height.
Old Oct 27, 2013 | 11:57 AM
  #36077
One bad black JK's Avatar
So if I am running a 3" lift with the bump stops from a 2.5" teraflex you think I would be able to cut mine?
Old Oct 27, 2013 | 12:00 PM
  #36078
D_engel's Avatar
Theoretically yes, but you would have to measure the compressed length of the shock to determine how high you can move them up. With the shocks that come in the 3" kit, you will probably only be able to raise them an inch or so.
Old Oct 27, 2013 | 12:07 PM
  #36079
ChesterJFK's Avatar
In your case you'll probably have to run longer bump stops, or shorter shocks. Do a flex test and see how much shock shaft is showing when your bumpstops are fully compressed.
If there is no shock shaft showing, then you cannot relocate the mounts. You'll have to switch to a shorter length shock, or add bumpstop but, then you'll have no travel. Lol
In my case I can't do this because I'm running 12" shocks on my 4" teraflex lift, with 3.5" bumpstops. I would have to go down to 10" travel shocks to move the mounts up 2", which isn't really worth it. I rather a lot of travel over two small mounts sticking out, you can reinforce these with skid plates and your fine. And I play in the rocks a lot.
Old Oct 27, 2013 | 12:08 PM
  #36080
ChesterJFK's Avatar
. I think he would be pretty close to bottoming the shock out with 2.5" bumpstops and 3" lift... If it's the correct length shocks..
