Old Dec 15, 2013 | 06:46 PM
  #36731
Jeepstin12's Avatar
Originally Posted by BRUT4CE
Lifted the jeep another 1.5" finally got it where I want... Did locker over ride so I can control front or rear seperatly and 4hi if needed as well as rear in 2hi. Made spring retainers front and rear to hold the springs in so I can now relocate shock mounts...
I'm curious. This is the first time I have seen someone use the term "over ride" when talking about the lockers. Can they still be used as normal, after the mod? I'm assuming you did the scotch lock on the purple wire mod???
Old Dec 15, 2013 | 06:49 PM
  #36732
ronjenx's Avatar
If it's the mod you describe with the purple wire, the lockers still work as normal with the regular switches.
Old Dec 15, 2013 | 06:52 PM
  #36733
Jeepstin12's Avatar
if so, I'm doing it! Thanks!!!
Old Dec 15, 2013 | 07:51 PM
  #36734
bombout800's Avatar
Installed my Evo draglink flip. Had to source a 13/16" drill but online as nobody local had one. While attempting to take both wheels off stripped out a lug nut(cheap lug nuts) cause someone put it on too tight. Bolted everything together and realized my aftermarket trackbar had less than a finger width of space between it and the sector shaft. Found a friend who just bought a 2013 and sold me his with 100 miles on it for $50 bucks
Old Dec 15, 2013 | 07:56 PM
  #36735
BRUT4CE's Avatar
Former Member
I cut and used shrink tube on top of solder at the box.
Yes the factory switch works still I did the negative mod.
The factory works like normal but the added switches will lock it and the locker that's engaged will flash but be working...the computer reads its on but doesn't read the plunger with the after market switch...
Doesn't shirt a thing and gives me control of my lockers when I need em...
Old Dec 16, 2013 | 01:18 AM
  #36736
Rbzak's Avatar
I added a transmission cooler.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old Dec 16, 2013 | 01:55 AM
  #36737
H8MUD's Avatar
Originally Posted by Rbzak
I added a transmission cooler. Sent from my SAMSUNG-SGH-I747 using Tapatalk
Is it a PITA to do and did you use MOPAR? I'm getting ready to do mine.
Old Dec 16, 2013 | 04:09 AM
  #36738
mattfl's Avatar
Finished off the rear bumper and finally trimmed the rear fenders!
Old Dec 16, 2013 | 05:28 AM
  #36739
Rbzak's Avatar
It wasnt that bad. Here a link to a write up from a other member here. I used the same parts and cooler
https://www.jk-forum.com/forums/show...mission Cooler
Old Dec 16, 2013 | 06:30 AM
  #36740
Pghchamp's Avatar
Default Wheeled it
climbed this hill
http://www.youtube.com/watch?v=ugvdVljkUI0&feature=share&list=UUw73icKARCOhNxWmyAYEg2w&index=1
