Old 09-20-2014, 04:10 AM
  #41271
Stephens2r's Avatar
Originally Posted by Tripletsi
Your have routed your brake lines incorrectly. They should be located behind the front shock to allow for flex during axle articulation. Like so:
Attachment 576327
Note how the zip ties are attached to the shock. It's two separate zip ties to allow the brake line to slip in and out.
According to AEV, proper brake line orientation is between the shock and the spring. You are correct about using two zip ties so that the brake line stays free while flexing.
Old 09-20-2014, 04:20 AM
  #41272
JLsJK's Avatar
From my understanding, if you run them between the shock and spring you need zip ties. If you run them behind the shock, the preferred method, you do not need zip ties.
Old 09-20-2014, 04:35 AM
  #41273
GreenJK07's Avatar
Got the broken shaft out. Now to get the splines out and in with the new:
Old 09-20-2014, 07:36 AM
  #41274
Chief_Airborne's Avatar
Installed a set of Inspired Engineering's cube's (spots) on the windshield and their 14" light bar (flood and spots) on my front bumper. Definitely diggin' them!
Old 09-20-2014, 08:11 AM
  #41275
Bpash2096's Avatar
Installed my new bumper.
ID:	576373   Click image for larger version
Old 09-20-2014, 11:20 AM
  #41276
GreenJK07's Avatar
Got my broken axle shaft out and found this.... time for a new carrier assembly...
ID:	576410   Click image for larger version
ID:	576411   Click image for larger version
Old 09-20-2014, 11:29 AM
  #41277
KevinMac's Avatar
- Oil change
- Removed stock fog lights (JW Speaker fogs on order)
- Bed lined inside of the freedom panels (looks way better than white!)
Old 09-20-2014, 11:59 AM
  #41278
Rub_My_Icon's Avatar
Originally Posted by KevinMac
- Oil change
Nice i been wanting to do this. Is that Rustoleum spray-on bed coating?
Old 09-20-2014, 12:18 PM
  #41279
KevinMac's Avatar
Dupli-Color, I got it at O'Reilys. Took about 1.5 cans to do the freedom panels. Next time the rest of the roof is off, I will definitely be doing that as well.
Old 09-20-2014, 01:27 PM
  #41280
Broncorif's Avatar
Sprayed an American flag on my bumper. It came out good enough that I'm going to add one to the other side. Click image for larger version
