Old Jan 15, 2015 | 01:53 PM
  #42341
AZ Honey Badger's Avatar
It was like Christmas today. Got my AEV induction hood, Trucklite LEDs, and Smittybilt synthetic rope 12k winch.
ID:	592094   Click image for larger version
ID:	592095   Click image for larger version
ID:	592096   Click image for larger version
ID:	592097   Click image for larger version
Old Jan 15, 2015 | 03:31 PM
  #42342
Icepick11's Avatar
Painted and installed my psc diff cover
Old Jan 15, 2015 | 05:22 PM
  #42343
twinz33's Avatar
Originally Posted by Icepick11
Painted and installed my psc diff cover <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=592113"/>
Are your rear shocks blown?
Old Jan 15, 2015 | 05:35 PM
  #42344
groovebus's Avatar
Finally found the perfect rock rails. White Knuckle Off Road in Apple Valley, CA makes the best rails and for a great price. I picked these up for $410. Had them welded on.
I needed a step for my short wife and young daughters, and I wanted a solid, weld on rail. The are designed to be bolted to the frame, but my buddy Scott Monks builds street drag racers, so who better to get to weld on my Jeep than someone who does it every day. He is up in Hesperia.
ID:	592128   Click image for larger version
ID:	592129   Click image for larger version
Old Jan 15, 2015 | 06:20 PM
  #42345
BubbaJK2012's Avatar
Originally Posted by groovebus
Finally found the perfect rock rails. White Knuckle Off Road in Apple Valley, CA makes the best rails and for a great price. I picked these up for $410. Had them welded on. I needed a step for my short wife and young daughters, and I wanted a solid, weld on rail. The are designed to be bolted to the frame, but my buddy Scott Monks builds street drag racers, so who better to get to weld on my Jeep than someone who does it every day. He is up in Hesperia.
Do they ship out of state like Minnesota
Old Jan 15, 2015 | 06:34 PM
  #42346
Jp3792's Avatar
Had a theif steal my new 50" light bar didnt even have it a month. So i made home made limb risers.. had light brackets with no use.
Old Jan 15, 2015 | 07:03 PM
  #42347
Clejxn's Avatar
Attachment 592134
Attachment 592135
Sux. Way to make lemonade from lemons.
Old Jan 15, 2015 | 07:25 PM
  #42348
Warpath66's Avatar
New decals
Old Jan 15, 2015 | 08:03 PM
  #42349
mds22's Avatar
Originally Posted by gsj8171
I copied someone on here by making a switch plate for my spot lights. This is the second time I made it. The first was with aluminum that was too flexible. This time I used an aluminum bar that I bought from home depot and made it long enough to add future switches if needed. I cut it with a metal blade hack saw and drilled it with a step drill bit from Harbor Freight. Then I filed and sanded it. I attached it with screws and nuts behind the dash. I like how it turned out for the most part but don't like the screw heads sticking out. I tried countersinking them but they are too close to the outside edge. Maybe I'll buy some rounded head screws. I also had a hell of a time pushing the switches into the faceplate. If you look close you can see the plastic tabs sticking out a bit on the tops of the switches. Is there a trick to them not sticking out? <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=592084"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=592085"/>
Why not just do it without the metal plate???
Old Jan 16, 2015 | 12:27 AM
  #42350
DJ1's Avatar
DJ1
Former Member
They ship out of state the only thing is the long lead-time since if I remember correctly, they're usually made to order.
